reverse lights not workin
976 Views 3 Replies 4 Participants Last post by  Darth_Stinky
my reverse lights on my r33 have stoped workin, bulbs are good and the mot is coming up!!! any one got any ideas??
if youve checked the connections find the reverse switch on the gearbox and jump the connection with a paperclip,if the lights come on its the the switch,if not its wiring
reverse lights are not included in the mot
I'd agree with Koh.
Volt meter over the terminal will also tell you if the switch is good & giving power....
Check for corrosion in the bulb holder & check fuse ;) Do you have green muck in the rear lights?
DS
