The spec is detailed in my project thread but basically the nos comes in at 3000rpm spooling the turbo, nos also causes greater efficiency at higher boost which reached 2.2bar (turbo is t04z with procams).what turbo/supporting mods are you running to get boost on that early and that power?
The dip looks worse than it is (drops about 30 ftlbs) and id most likely to be related to cam timing. No wheel spun as mapped on dyno blocks at MGT. Drops off as was last run and nitrous pressure dropped off (bottle nearly empty).Who mapped it this time and why the massive dip at 5k? did it suffer wheel spin? impressive figures but the torqur doesn't have drop off after peaking. Still will be a bloody handful mind.
