I would be cautious, if you're running stock ride height you should be fine as the tyres probably won't get anywhere near the arches. If you're running a low ride height without any camber correction again you may be ok.
I would say you will need to go for a slight stretch on the the front and rear. I have a 265 on a 10" and a 225 on a 9" on mine with higher ET's and they only just fit without a roll on the arches. I am running a fingers width arch gap from the tyre to the arch and have front and rear camber correction to prevent inner tyre wear due to excessive camber.
If in doubt find someone with the same size and (as above) trial fit before you buy.
Ian.
