is any rotational play acceptable in outer universal joints? my 98 R34GTT has about 2mm both sides, could this be worn UJ, or maybe worn splines?
All old rubber bushes have been replaced with polyurethane a few years ago
thanks damo, that's encouraging, hopefully we will find someone who can tell us for sure
Discussion Starter · #4 ·
hi Damo, The brake drum for the handbrake is behind the disc and its the play in the mechanism that is the slight movement. Perfectly normal.
Take the handbrake off and you will probably get up to an inch of free play. All ok
