1 - 2 of 2 Posts
I am having issues with trying to keep my car running.
About 3 weeks ago on a Sunday the radiator blow cause all of the water had disappeared after only checking it on Thursday of the same week.
I have replaced the radiator & the rocket cover gasket which was making it run ok.
It is slow to take off from standing still, it is shuddering when idol & also gutless on hills (drops down from 100kph to 80kph on the Bombay Hill). When I try to get it up to 100kph again it over revs.
Now today when I went to come home from work the revs aren't there till it gets out of first gear then runs fine but if I have to stop a the lights or need to slow down it takes ages to get moving properly again.
Anyone have any ideas on what could be wrong & how to fix it?
It is a 94 R33 with an RB20E motor.
sounds like a transmission problem. Have you check if the levels are alright?
Either trans converter is on its way out or need to replace some of the trans modules underneath the trans case, incase its blocked, causing it to stay in gear 1 longer
1 - 2 of 2 Posts
