rb25det cylinder head with tomei pon cams, 8.8mm valve springs and tomei adjustable exhaust pully,
greddy stle plenum
top mount tubular exhaust manifold
gt35/82r garrett turbo
nismo oil cap.
plenum and turbo inlet are off to the polishers asap along with cam covers, cambelt cover and other little bits and bobs
just need the following now!
80mm anodised throttle body
injectors (unsure what cc to go for yet)
head gasket (again unsure whats best thickness)
tomei cambelt
n1 oil pump
n1 water pump
alloy rad
fuel pressure regulator
high flow fuel rail
uprated fuel pump
management (not sure whats best at the mo)
splitfires
plugs
afm (unless i get management that runs without?)
