1 - 20 of 21 Posts
I hit an all time high 0.75 this morning. I've heard that the ceramic turbo can only safely take 0.8.
Is 0.8 a safe max or is it terminal level?
What's gonna happen when if I exceed the maximum, will it be and instantaneous bang or something more subtle?
M's Factory
seriously dont think you have a problem mate at that boost pressure. Just on colder mornings you will draw more boost.
Discussion Starter · #8 ·
I hit 0.8 BAR (11.60304 PSI) this morning! and I wouldn't say that the ambient temp is even that cold yet!
The above article states that 9-11 PSI is the safe level for a RB25DET.
So what needs to be done to control this guys? The above says something about getting someone to check it on a dyno?
What should be my first course of action?
M's Factory
If you are running a power FC turn your biases down within the boost section, or if you are running a boost controller set it to a lower setting on a day like this.
M's Factory
So are you looking at your boost gauge ?
Do you have an accurate boost gauge ?
I find standard ones are quite off.
Discussion Starter · #12 ·
Na I have a turbo timer, which records the peak boost reached.
After you advised me to keep my eye on creeping boost, I set it to warn me when I went over 0.66, which was the highest I had reached previously.
M's Factory
ah i see, ok it depends on what you going to do mod wise ?
Discussion Starter · #14 ·
To be honest I am really happy keeping her at stage 1.
I wasn't planning to do anything other than dispose of the silly Jap sized seats!
M's Factory
i would say just get a boost controller then :)
I'm starting to get quite worried about mine too now to be honest. When I first got the GTR I was only hitting 0.90 bar boost now I'm hitting 0.97. Just need to make sure I don't get over 1.0 bar. If I do it's time to buy a boost controller me thinks.
M's Factory
yes indeed.
M's Factory
they arent expensive depends which one you go for isnt it.
Do you go for one that does what you want or do you go for a rolls royce ? Its your choice.....
Discussion Starter · #20 ·
:rolleyes: dam, you kinda got me there, I do seem to be attracted by brand names:rolleyes:
Blitz do one (which looks nice :D ) for over £500 :eek: :eek:
Maybe I'll shut up and go bargain hunting. Any suggestions on things to aim for or avoid like the plague
1 - 20 of 21 Posts
