1 - 3 of 3 Posts
Hi Guys,
Can someone help on the issue i am facing? Climate control in my 35ogt is playing up, it blows cold air when set on 18c (lowest) as normal but when temperature is increased 18.5 or above,it blows really hot air as temperature is set to highest. there is either cold or really hot air blowing. has someone faced similar problem? will really appreciate your advise :)
Thanks.
Welcome!
Usually anything relating to variation in hot/cold relates to the PCB board for the heater controls.
You can resolder this - it will likely fail again or replace with double din (oem from jauce, metra etc)
S
It's funny but I a problem like is ( or is it just theses cars)!
Cold start, 2c outside, i had heater set to auto with a.c off, 5 minutes into driving and engine/ coolant warming up and heater is set to 19c so blower is starting to blow out hot air.
Normal working climate control I hear you say, yes that's right.
But if I drop the temperature to 18 c it blows cold air, 19c and hot air, yes this is normal if interior has been sitting at 19c for a while but not then interior is not warn yet!
1 - 3 of 3 Posts
