21 - 40 of 45 Posts
Oem wheels for sale
Oem 350GT wheels 9kg a corner
These are the oem 17x8 (All round I believe) wheels for this model. Apparently they weigh 20lbs (without tyres) which is 9.072kg
As you'll see from pics 2have some light curbing and others look fine. Tyres will probably need changing though!
£100 I'm not offering to post but you want to sort a courier that's all good.
http://www.skylineowners.com/forum/showthread.php?p=2613873
VQ35DE Engine for Sale Very Low Miles only 2k
VQ35DE 3.5L Engine Skyline 350GT/Infiniti G35/350Z. £2995
VQ35DE 3.5L Engine Skyline 350GT/Infiniti G35/ 350Z Extremely Low Miles 2K only | eBay
Removed off a Infiniti G35 2005 ex Infiniti demo car. Extremely low miles only 2000 miles.
Same engine as in 350Z / Skyline 350GT / Murano
Engine is as new, Very clean and strong engine, no smoke or rattles.
Seen running in link below.
https://youtu.be/G_YqTMj4yxQ
Excellent condition. Can be used either as a replacement or project build. Perfect platform.
Engine excludes starter, alternator, ac compressor these will be sold separately.
Includes injectors, coil packs, Mass Airflow
Engine stand can be included, but must be collected with the engine.
Please call for any further details.. postage also may be arranged at a cost.
Skyline 350GT/Infiniti G35/350Z Automatic Gearbox 2K miles only
Automatic Gearbox for a Skyline 350GT/ Infiniti G35 / 350Z £500
Skyline 350GT/Infiniti G35/350Z Automatic Gearbox 2K miles only | eBay
Removed off a Infiniti G35 ex demo car with extremely low miles 2K only. Excellent condition like new.
Same as Skyline 350GT and 350Z. Same parts.
Call for any details. Collection or delivery can be arranged at a cost to buyer
07453496430
NISSAN Skyline 350GT / INFINITI G35 Coupe/ BREAKING for Parts, Spares
Hi all,
Breaking a 05-06 Infiniti G35 Coupe / Skyline 350GT V35 for parts and spares only (whole car breaking).Ex Demo Infiniti UK car - Very Low Mileage only 2000 miles, the parts are reflective of this they are like new.
NISSAN Skyline 350GT / INFINITI G35 Coupe/ BREAKING for Parts, Spares Wheel Nut | eBay
Parts that are available I will try to list that are directly compatible with 02-06 Skyline 350GT (may forget ), anything not listed assume either sold or just ask of availability:
VQ35de Engine (incl ECU sensors, mass air flow, injectors spark plugs and coil packs),
Engine Ancillaries (Alternator, Starter Motor, AC Compressor)
Engine Cooling Rad + Twin Cooling Fans
AC pipes + AC Cooling Rad
Torque converter,
Flywheel,
AT Gearbox (incl Gearbox ECU)
Brakes (non brembo) Calipers and Pads,
Suspension,
Upper and Lower Control Suspension Arms (Front)
Rear Subframe and W
Differential,
Propshaft,
Drive shafts,
Boot lid + Spoiler,
Shell (rear quarters)
Front Bumper + support
Front Headlights (inc all bulbs HID, Ballasts and cable)
Right side wing mirror
Left Side Door and Handle
Front Drivers and Passengers Glass Window
Left side rear quarter glass
Rear Glass Window
Bose Speakers
Leather Door Carpet
Right side Door Actuator and Mechanism
Right Side Window Regulator Motor
Front and Rear Seat Belts
OEM 6CD changer and Radio AM/FM
message or call for details
Hi, so is the Torque converter with this?
You say it's done 2k, is this right?
Any inside trim? - i.e gearlever panel and panel under armrest in black?
Thanks.
Yes mate the car only covered 2k only hard to believe right, was a demo car.
Currently the torque converter is not included.
there are some interior panels left, if you are enquiring about the gear level or gater then unless your car is 05 onwards it may or may not be compatible.
thanks
thanks
Hi, so the interior panels around the gear level are the newer rounded version then. Mines a 04.
The reason I ask about the gearbox etc is I have a fault with mine. After hard acceleration and then lifting off throttle before the auto gearbox changes into 5th, it will sometimes 'bang' into 5th.
So I'm thinking it's a gearbox fault but I was checking yesterday for movement in all rear bushes and found about 20mm of play in the propshaft carrier, so now thinking this could be the problem.
Do you have the propshaft from the 2k car?
Thanks.
Thanks.
yes, check the listings all should be on there.
21 - 40 of 45 Posts
