1 - 20 of 27 Posts
oversteer is king
Have you ever had one before coz I had a double but found I hit it every time getting in and out of the car thats why I threw mine away
516ATF and RWD......Nutter!!
To fit that one you have to remove the original pillar and this replaces the whole lot.....looks much neater.
I've got a double and only slight issue I've got is I hit my hand on it when the steering gets a bit lary :D
Other than that...no problem....never hit myself on it.
The plastic trim that runs from by the dash and up over the door to just above the seat belt.
Yeah probably or get the double for the pillar and a double for the dash and get another gauge.....can't have too many gauges lol
Tell me about it.....I think he needs a full time co-driver to monitor them :D
pod passenger side are: exhaust temp, oil temp & water temp
pod over the steering wheel dash are: 2 fuel pressure gauges (monitoring what each pump is doing)
A-pillar are: Boost pressure and Oil Pressure
Fair enough......just looks a bit cluttered all the 3 pod ones I've seen.
Track addict
i have the twin pod pillar from indigo gt, looks very neat and tidy.
Could you mount your 3rd gauge on the steering wheel cowls??, i have my air fuel gauge mounted there so its right in the line of sight.
I also have 2 gauges mounted where the center air vents were, so maybe thats an idea???
Im not a huge fan of the dash type pod mounts really, but it's down to personal choice i guess
1 - 20 of 27 Posts
