hi anyone know how to get a stereo out of an imported car,(r33 gts) its still set to japan frequency and i dont want to start ripping the dash apart to get it off without knowing what im doing.
Dorset/Wilts Area Rep
From memory as I didit over the weekend
  • Take out the ashtray
  • Remove revealed screw
  • Unscrew Gearknob
  • Remove gearknob surround - gental pull required to unhook.
  • Undo cigaretelighter power
  • Undo 2 screws that are now visable
  • Adjust steering wheel to lowest setting - if poss
  • Pull from button to unclip dash.
  • Unclip all connections and the hose to remove dash
  • Undo 4 screws that hold stereo in
Refit is reverse
... is modifying the driver
I had the dash out today to replce the ggators and give the car a good old clean, so decided to fit a frequency convertor but got stuck on where to put the red power lead ?? instructions just say "connect to a 12v supply" any guidance would be much appreciated :cheers:
i would use the live feed from the ciggy lighter myself
