Looking to import and purchase an already imported GT-R R32 in the coming months and i want to put together a parts list of things to support the block before power on the block. Pretty much all bolt ons. I was looking to see if i could receive any community recommendations on the brands to use. price is no object. I know there was many things around made then discontinued and i just want a second opinion before i getting this that the third. Thank you to all who want to comment . Looking for Max power on stock turbos/ stock internals for now like a 450 WHP goal
Oil Pump - HKS
Magnet Transplug - ??
Oil Pan Magnet Plug - ??
Cold Air Intake - ??
Turbo Back System - Tomei Full System or HKS System??
Headers - Tomei???
Intercooler - ??
Radiator - ??
Air Oil Seperator - ??
Oil Cooler - ??
Intake Manifold - ??
Water Pump - ?? ( Not the N1 Water Pump im not going to have a N1 Block since the elongted hole thats on the flange seeps on the none N1 Block )
Boost Controller Solonoid - ??
Should i get anything for coil packs or ignition??
Also going to upgrade the stock twins internals
Turbo N1 Upgrade Kit for Nissan Skyline R32 r33 GTR RB26 RB26DETT Nismo | eBay
Hope fully the link helps anyone else trying to ditch the ceramic and also make them even better.
You should probably decide what kind of power you will be making or what you will primarily be using the car for before purchasing anything. Different recommendations for different level of builds or uses.
Ive adjust the post for my goals i knew i was forgetting something Thank you.
Oil Pump - N1 is fine
Cold Air Intake - not technically needed, whatever you want
Turbo Back System - something custom made.
Headers - stock is fine
Intercooler - stock is fine, good till almost 600hp
Radiator - stock is fine, or koyo
Oil Cooler - probably not needed unless tracking the car
Intake Manifold - stock is fine
Water Pump - stock is fine
Boost Controller Solonoid - ask your tuner
Should i get anything for coil packs or ignition?? - ignition, no. coilpacks, no. if it works, it works. if it's old, replace with oem stuff.
