1 - 3 of 3 Posts
Anyone help Please,
My daughter has a skyline 95 model, Rb something motor. Anyway, it was stating and running last week, then we went to start it nothing! It has an emboliser, so we have repleaced the starter with new, battery has been checked and is fully amped and charged.
Symptoms: Dash light dim when key turn, stater engages but no crank. just the click from the starter.
If in doubt...
KH3 ECR33
Sounds ike something is seized and not allowing the engine to turn over.
My advice is to check to see if you can turn the engine over with an extension bar and socket on the crank bolt. If it won't turn over by hand then start taking the auxiliary belts off one by one, checking to see if the engine turns over each time you remove a belt. It's possible that one if the ancillaries has failed and seized i.e. alternator, water pump, A/C compressor, etc. Could also be the engine seized itself but the above process will tell you that anyway.
1 - 3 of 3 Posts
