1 - 17 of 17 Posts
Hi guys just a question lately the front of my 03 g35 dips and the slip comes on when turning not even that hard quite anoying any suggestions maybe shocks or something
The slip control has no sensor that will react to worn dampers, other than the yaw sensor, are you talking about the light coming on while cornering or just when maneuvering?
What do you mean by dips? is there excessive body roll when cornering or braking?
Ya its when im turning the front of the car dips to the oppersite side i am turning body roll it skids and slip comes on
Ya excessive body roll when cornering seems ok when braking though i dont tend to hammer the breaks
Worn dampers will make it feel unstable at speed, especially with direction changes.
Might be worth checking the front control arm and anti-roll bar bushes and connections for anything worn or loose.
Also I had a similar problem with slip light coming on while cornering, did a steering angle reset with NDS and it hasn't happened since, could be worth a try too.
So while im waiting for my garage to fit me in to have a look see what is going on what coilovers do you guys have and any info prices etc please
...dude, been discussed plenty of times. Try here ;)
BTW I will be putting my Miesters up for sale soon (just gotta wait till I get to the magic 100 post count)
Discussion Starter #14
So now i have a creaking noice when i turn left ot right must be another symptom of the same problem ( suspension) what u think guys . Im still waiting for a day off that matches a slot for my preferred garage
Could be drop link bushes.
Discussion Starter #16
So finally got the car to the garage and we noticed the lower controle arm bushing had dplit so was thinking of upgrading the arms so where do u guys recommend to buy them
It is all down to your preference mate either you go second hand, brand new from suppliers off the web, and there are also others and companies on this forum who can get what you want. All you got to do is search for it. Its probably been discussed on here many times and you may be lucky to find a thread that already discusses it. good luck with it.
1 - 17 of 17 Posts
