What's the max hp you can drag out of the standard AFM before you need to go up to a Z32 one? And how much boost can the engine take on the standard head gasket?
If I was to change it for a steel one, what's the best thickness/bore size and gasket type? I've seen all sorts of different bore sizes available, plus seen gasket listed as 'bead' and 'grommet' type, or something close to that. Can anyone shed some light on what those mean.
