1 - 10 of 10 Posts
Hi all ,
Ive just bought a skyline r33 gts 1993 , i got it imported
through xlautos down in devon. www.xlautos.co.uk .
I will proberbly posting a lot here due to my muppetness where
imported japanese cars are concerned so ill thank you all in advance for your time and patience .
The car is completely original and has done 60.000 kms , so its a nice blank canvass to play with.
What i would like to know first is about speed limitators , do all jap imports have them ? and if they do where can i get the parts
to sort out mine .
Many thanks Paul :40oz:
Discussion Starter · #5 ·
Hi again guys ,
Thanks for your replys , so just cutting wire 53 on the cpu loom will do the trick ?? Sounds so easy .
Will doing this have any other effects ?
cheers again guys
Cutting wire 53 is all well and good, but as far as I remember they are not numbered on the ECU plug, so have a look for a wiring diagram so you cut the CORRECT wire if you don't buy a convertor. Limit is 112 MPH I believe (or the KMH equivalent).
1 - 10 of 10 Posts
