1 - 13 of 13 Posts
Quick question - I know from factory there is a 112mph limit on the Jap import R33 GTR, what is the limit on the UK spec cars?
Mine is an import but has got an ECU from a UK spec car. I was trying to get a top speed the other day (on a legal track day of course ;) ) , and at what was showing on the dial was about 156mph when the car lost power and sounded and felt like a speed limiter. I slowed a little floored it agian and the same thing happened at the same speed. The revs where only at about 6500 and everything else looked normal - EGT was about 890 and boost was just over 1 bar.
Was just wondering if the UK ECU's have a 155mph limit?
M's Factory
There isnt a limit on UK spec cars as far as I am aware, althought I could be wrong, anyone verify this ?
Might be an integral unit in the car restricting the speed of the car.
M's Factory
ooer maybe its just read off the speedo, ie your speedo will still be out.
True, I have got 19's on so I should imagine it should be out a bit.
Guess - my next question is - How do I remove the limiter????
G
there is a wire u can cut , that removes the speed limiter , i think its pin 52 on the ecu , but cant be sure , do a search on sdu .
Cheers for the info.
SDU says if the wire is cut "This impacts the HICAS diagnostic mode - will not exit the diagnostic when 10kph is exceeded"
What will this mean to driving? will the HICAS still work do you think?
Ant, this will only affect you if you put the hicas into diagnostic mode.
There was a thread in the tuning area about how to do that - having seen it you'd never get it into diagnostic mode accidentally.
there was a UK version of the r33 and r34 gtr
1 - 13 of 13 Posts
