Hi,
We can now offer Splitfire Di Ignition coils for £357 inc VAT.
Here is some info
Indigo-GT: Online
Here is some info
Indigo-GT: Online
The SplitFire Super Direct Ignition System is designed exclusively for the Japanese T high performance engine. This system replaces the original equipment coil pack and ignition wires with a direct ignition coil on plug system. The increased ignition performance found with the SplitFire Super Direct Ignition System is a must for all racing and performance enthusiasts.
Increases horsepower at the top end of the RPM band
Ensures and maintains maximum energy supplied to the spark plugs
Reduces incomplete combustion caused by misfire
Eliminates RFI (radio frequency interference) by eliminating the need for a wire set
Easy installation designed to fit the high performance engines
Please Note. The difference between the RB25DET series 1 and series 2 Splitfire coil
packs are the igniters. The series 1 have separate igniters, where the
series 2 are built in. You should be able to tell by looking at the
existing coil packs. Alternatively you could look up the engine number
with Nissan.
