Need some advice ,hope somebody can help. Car has just failed mot on leaking shock.Bought set of used gab adjustables with no springs but the springs i got are too big a diameter. They are kyb shocks which i am sure are non std even tho they are'nt adjustable. Just wondered if any after mkt springs i buy are going to be the same. The adj rings are 80mm outside dia.
My other idea is to do a bit of blacksmithing and close them up a bit. I would only need to heat the bottom. Whadya think?
