Hi,
I have a Spec2 R33 GtsT that had the steering Wheel removed and changed for an arftermarket MOMO Wheel with boss kit, the previous owner had removed Everything behind the Wheel such as the connectors for airbag and hicas and horn...
The horn button is relocated to the side of the ashtray. The only Cables that are loose is under the steering loom where i found a connector with six Cables in it.
I wonder where to put the resistor in order for the airbag light to work as normal, beliving the airbag is still in Place.
The resistor i have bought is a Luisi kit. The connector under the loom is with six Cables and i need to know wich ones to connect to...
And please remember that i have tried to black out the light with duct tape but it wasnt okay... Need to have it streetlegal with working airbaglight...
Please help quickly! :attention:
