hi does anyone now wat the standard boost is on a r33 gtst i thought it was 7psi but just fitted aftermarket boost gauge on on full boost its reading 9psi
thats correct, some do vary slightly......85 is what you can achieve with either a boost controller or different actuator pressure ie change spring....i thought it was 5psi then went up to 7 cheers lo mate
so do you think i got a slight problem or is 9psi okthats correct, some do vary slightly......85 is what you can achieve with either a boost controller or different actuator pressure ie change spring....
