I drove to my daughter's graduation the other day and everything was fine. An hour later and the car wouldn't start. It doesn't want to crank at all. Battery is fine, even tried to jump start it with another battery but no change. The only way to get it going was to push start it.
I have tried to change the starter motor but there is no change at all, same behaviour.
What is there to check next?
Check your relays I had the same problem and I found out it was my starter relay and I had a bad battery I changed them both out and car was working once again even better at that:bs2:
