Hi guys my r33 gtst has been in storage for over 2 years what's needed for first time start
keys in ignition,charged battery check oil and water level then turn key to start
Is there a need to put a little oil in bores as I heard it is better for it if been sitting?
Unplug the CAS unit on the front of the engine and with the key in the ignition turn it over until the oil warning light on the dash goes out ~30secs or so. This will allow you to move oil around the engine and build pressure without firing it up. Plug the CAS back in when you are ready to start.
