1 - 3 of 3 Posts
i have got a problam with car starting from cold, it turns over sevarel times then fires , then revs slowly build up then its fine, some times when the weather is hot it will start at the touch off the keys...strange eh... its just been on r/r at the weekend and every thing is fine, i have had a good look round but found nothing so was wondering if any body else has had same symtoms and fixed it....
1st RB20DET S13 in UK
Maybe the lambda's a bit slow to heat up to temp?
Mine did this also, but has been much better since using my LM-1 wideband sensor to 'simulate' the normal narrowband sensor.:)
1 - 3 of 3 Posts
