Steering Rack questions
962 Views 6 Replies 2 Participants Last post by  z28evans
Anyone have a parts diagram for a steering rack (mines an r33 , but it may apply to other years as well).
Also, is the rack shared on any other platforms - 300zx, s14, etc?
I'd like to get a rebuild kit with new seals, etc - so i was hopeing that there was a similiar platform that i could get parts from.
I'm not going to be using the HICAS, so i was going to pull the sensor from the rack so i would have more room (if i understand it the system varies the pump pressure, not the pressure at the rack).
thanks,
james
From memory (andf I could well be wrong!) there was no seal kit available, only replacement racks.
However I recently sent an R33 rack off to a Hydraulics Specialist firm to see if the seals could be obtained or manufactured...
thanks for the info, i am looking at possibly using a 240sx rack for my application.
I am afraid I only have UK and JDM FAST available.
So I can't check the 240SX LHD racks for you :sorry:
Have you searched Stateside forums like NICO etc?
Chris
I did some searching , but last night i did the mock up and the r33 rack is fitting fine without much modification. Thank you for your time.
Here is the motor swap i'm working on ( turbo ls1 swap)
thanks, james
Hmmmm
LS1, turbo conversion....
Not much shortage of torque then!
What turbos are you using on that lump?
Chris
not sure which turbos - probably twin, but still debating. Aiming for a max of around 700, i'm mostly into drifting / track days and not looking for a crazy amount of power.
I'll post up my build thread on this forum soon.
thanks,
james
