Hi Peeps.
I have a small problem with my Skyline R32 GT-R. The Hicas light in the dash turns on for 1 sec. and then it's off again. I't dosen't matter if i drive straight forward, in corners or holding for a redlight. It turns on every 5 minutes for 1 sec.
When it turns on and i'm turning the steering wheel, it makes a small "kick". :drivin:
Are there any others who have tried similar problem?
Regards Streethers.
Lincolnshire Area Rep
Wheels the same size? One or two tyres worn can also cause this issue, the rolling radius needs to be the same on all four corners. If thats all good get under it and look for worn bushes and the like.
The wheels are all the same size. They are 18x9,5 et30. They are also pretty new. I can feel the "kick" is electronic or from the pump?
I have been under it, all bushes and suspension are fine. I also just got a four-wheel alignment.
