I baught these off a mate (also a member of the SXOC) he had them on his car for bout 20.000k and I had them on my car for 7.000k. 1 of the rears has had the outer lip repaired you cant really tell unless you look really carefully. All 4 hold tyre presure too :nod:
Fronts wheel size is 17x8J offset = 35. Have Bridgestone Potenza REo4o 215/45/R17 tyres with 5mls tread left. One had bald inner Tyre due to camber!
Rear Wheel size is 17x9J offset = 38. Have Eagle F1 Goodyear 265/40Z/R17 both have bout 1mm evenly worn Tread left from the inner tyre.
rear right
rear left
pics of the damaged alloy
one of the alloys has som slight damage from were a locking nut got stuck so i had to hammer a nut on, but this cant be seen because the caps cover the nuts up
im looking for £220 + delivery or pick from SW4 clapham
