Hi All, first time posting on this forum!
I have a 1993 R32 Skyline GTS-T with RB20DET and I'm in the middle of doing a timing belt and water pump replacement.
While troubleshooting some issues with the tension of the timing belt (engine sounds like it has a super charger), a worrying knocking/tapping noise has developed from what i think is the valvetrain/head area. I'm quite worried about this as its appeared out of nowhere and hasn't happened on this engine before apart from the first second or two after cold starts.
I've heard that some noise from the lifters is common on RB engines under certain conditions, but this coupled with the work being done on the timing belt, removing spark plugs etc has me worried.
Some background:
The car hasn't been run up to temperature and driven around in over a month, the car has been jacked up at the front for about a week and its been really cold here lately.
I'm running a 10w50 oil but this hasn't been a problem before at these temps.
I've uploaded a video here which might help identify the noise. The supercharger whine can be ignored as thats looking likely to be an over tensioned belt or one of the belt bearings.
I'd appreciate any help in identifying if this is an issue or something that will go away when the engine warms up! Thanks
Some background:
