Space Filler
I got the stuff to do the brakelight mod that let's you turn the inner two lights into foglights. Rather than wiring the diodes straight into the light wiring, I've decided to make up two small circuits that will tidy things up.
Anyone know of a simple program, ideally freeware, that can be used for laying out basic circuits, so I can have something to print out to transfer over?
This is my idea for the boards. They'll essentially be identical to each other, although one will take it's foglight switch feed off the other board. (The contact in the bottom right)
User of V-power
no idea on the software? not quite sure why you would need it?
but i did this mod and it works very well,
let us know how you get on.
Dazzler
Just use one of the rear reverse lamps as your fog lamp instead, much simpler and you still get the skyline signature 4 brake lights! I just used a silver coated red bulb and you cant tell at all until you put the fog lamp on. :D
