When I bought the car, it already had a HKS kevlar timing belt on it; apparently it hadn't been on long. Upon inspection yesterday, there is a very, very small slit in the belt. I hadn't noticed it before but it doesn't look like wear and tear, more like a scalpel cut not a rip.
I'm going to go for another kevlar timing belt and have it replaced; was thinking of going for a tomei kevlar belt for my rb26 as they come quite highly rated. Does anyone have any recommendations for brand/type?
Also, I'd rather a professional do the job for me; not really sure I need the pulleys/tensioners doing although an inspection would be nice. Any ideas how much labour this would cost? it was quite expensive on the scooby due to the placement of the timing belt but the timing belt cover on my skyline is already off atm so I would have thought it's just the time it takes to undo the tensioner, take off the old belt and then put on a new one. Finally, do you guys run the kevlar belts with a little slack on cold start so that they are the correct tension when warm?
