i set my timing yesterday to 15 degrees with thr first yellow mark being tdc then 5 10 15 so the third white mark being 15, but now the car ticks over at about 1200rpm and nearly 2000 when cold, have i done this correct
its a 1995 gtst by the way, cheers
Track addict
You need to have the throttle position sensor unpluged when making any adjustments, to the ign timing
Track addict
I would put it back to how it was, then disconnect the battery to reset ecu, then start again.
