First off. I need to have a towbar on the skyline. So please no WHY do it posts.
looking at the rear of the car with the bumper off its just like many other cars. With a chassis section at each side and as luck has it a flat'ish rear panel.
So the starting point was a Mondeo mk1 towbar. This was about 30cm too short to fit as it was so i extended it. I will be making a full centre section out of 50mm box section when i get some, but for now this will do the job.
A chassis plate was made for each end where the rear bumper iron would normaly fit, this bolts through the chassis with 4 M10 bolts.
Next a stress carrier was made from 40mm angle bar. This is to help spread the load when applied to the towball. This bolts on to the rear most bolt holes that held the bumper iron in place.
2 long bolts and spacer tubes then bolt through the rear hitch plate, rear panel and into the stress carrier bar.
Then bolt the lot on.
This is the towbar sections bolted together on the floor.
And as it fit to the car
I have made it so the towball section is removable. It bolts on under the number plate.
With the tow ball on
And with it removed
The towball and electrics all stow away in the compartment where the jack is, neet and out of the way.
Rob
And with it removed
Rob
