1 - 14 of 14 Posts
Registered User
17s id go for.depends on what brakes you will be using and what wheels.id have a light wieght set of 18s over cheap rubbish 16s
D
Guest
I used 18" for years on track days and loved em, If the tracks a good one they give alot more feed back, you can fit bigger disc's to :)
You could argue that the 18's would have a marginally greater contact patch than 17's. Have a look at your chosen tyre manufacturers website and see what the best tyre range is for a given diameter of wheel. Sometimes that will make the decision for you.
TT
Registered User
that would be a good setup.sparco wheels are very light and r888 ive heard are the best road/track tyre.
AKA RSP
We use 888 on our demo cars and they are a great all round tyre. Obviously they do wear a little quicker than the Toyo T1R`s. You`ll also find they are suprisingly good in the wet for a semi slick.
Richard
Thanks for the info looking forward to our next track day,now which brake setup on std discs with red stuff pads at the moment.
Yeh go for the lightest forged wheels you can find - then put nice R888's on and you should be flying :D
R32GTR wheels are good cheap ones too as theyre pretty light and mega strong.
Hey your from S.wales - where to? You dont happen to have a Gunmetal R32 with silver wheels do you?
Butuz
Hi Butus, met green r32gtst we met at W.Wales meet, did you fit my old HKS panel filter.Hoping to be at sunday meet on 29th.
There's normally a big difference between a 17 and 18 wheel in terms of weight. Check the respective weights first.
Something like a Compomotive MO would be nice :)
Registered User
i agree mo's would be nice.weight is the main thing as unsprung weight is bad it does afect handling alot.
1 - 14 of 14 Posts
