Help needed to connect my gauges after removing my xanavi satnav, i need the wiring loom from the back of the gauges to where they should plug into any ideas where i can get my hands on one :bigthumb:
jdm garage
Discussion Starter · #4 ·
Thanks once again Ian sent them an email went on the Aussie site they say it can be done as the GTT has a standard loom you just need the extra looms etc they even gave you the part numbers req so once i have completed this little project i will post a how to do list.
Discussion Starter · #5 ·
No luck with the wiring harness so i have took the plastic bit off one of the leads to the xanavi and connected them seperatly to their relevent positions. Connected the bulbs and ignition feed wires from the hazard switch going to go to mgt racing to find out about the oil and turbo sensors and then trace back wires to the interior then branch off from there so nearly there. After they are all connected just got to sort out a bit of facia but at least the end of this little project is getting closer.
