1 - 20 of 21 Posts
We are now suppliers of TRS :)
So we have a selection of Tow Straps in stock
This MSA compliant fabric tow strap from TRS is suitable for fitting to the front or rear of the car.
Red, blue, black and orange two loops are produced using 5000kg break strength webbing. Yellow, green, and silver tow loops utilise 3000kg webbing.
Standard length 270mm £10.50 each plus postage of £3.90
Colours available Black, Red, Blue, Silver, Green, Orange and Yellow
Extra long 350mm £12.50 each plus postage of £3.90
Adjustable with a loop up to 24 inch (610mm) £14.50 each plus postage of £3.90
Available in all 7 colours
pics up shortly :)
Samy
do you have any pics of them on your car and does it need a bit of bumper trimming to fit these
im very tempted but i dont want to cut up my bumpers
doh didnt read it correctly
when you have them in stock and fitted pls put up some pics
... is modifying the driver
Discussion Starter #5 (Edited)
The short strap is standard sized the longer is one we have ordered with extra length to clear our bumper
but please note the picture of the one fitted really depends on what bumper you have and where you have decided to attatch it?
tbh too mount it correctly will need a hole in the bumper as there are no real structural points on the bottom of the subframe only on the sides of the chassis rails,
If in doubt I would get an adjustable tow strap then you can fit it where you like but it needs to have a clear path anything it goes around will possibly get bent if it's towed, bumper, intercooler etc :)
Matt
were did you mount the strap to
i dont have a intercooler as of yet
but am i right in thinking the metal bar that supports the rad is were you have bolted your to
seeking to be one of thee top DE+t conversions
theres pics of a front and rear on my car too if you want to have a look thru my project thread
I will get some of the adjustable straps in as as well, this way they can be bolted to the chassis leg where the original tow eye's are,
Unless you have a bracket made though I'm pretty sure the bumper will have to be altered to get the straps mounted to a structural point and that won't damage your bumper if you need to use the strap
Matt
Discussion Starter #11
yes it's a problem as most have different bumpers, intercoolers lol so fitting can vary alot!
I've got one fitted too, heres a couple of pics..
Hi mate, interested in adjustable one in red mate. Can you PM me detail for payment and date you getting them in, plus colour if red not available
Discussion Starter #15
Red Adjustable Tow Straps now in Stock:)
Adjustable with a loop up to 24 inch (610mm) £14.50 each plus postage of £2.75
Samy
Discussion Starter #16
Adjustable Tow straps in stock, colours available are
Silver
Yellow
Green
Black
Red
Blue
Samy
East Ireland Area Rep
do you still have these in stock?
looking for a short black one to fit original rear towing eye and one long enough(black also) to attach to the front towing eye hiding in under a GTST series2 stock bumper, dont want it trailing on the ground, but dont want the bumper tugged either if i have to use it etc
Discussion Starter #18
Hi,
At the moment we only have the following in stock
2 x bark blue short (standard size)
1 x Orange adjustable
1 x Blue adjustable
We have the black ones on order and are due in, in about 2 weeks.
Samy
Discussion Starter #19
Standard size TRS tow straps back in stock £10.50 + £3.90 uk postage
Colours available:
Red
Blue
Silver,
Yellow,
Black
Green
Samy
Discussion Starter #20
Extra length ones now in stock £12.50 + £3.90 UK delivery in the following colours
Red
Blue
Black
Orange
Green
Yellow
Samy
1 - 20 of 21 Posts
