1 - 3 of 3 Posts
Um. . . I have never taken my bumper off but need to do it to get to a few bits behind. I'm sure it's easy but my car is quite low and can't figure it out!
Is it just 2 10mm bolts or is it on slider things or what?
Points don't mean prizes!
If your talking about the front bumper then iirc it's two bolts in each wing, take out the front grill piece, these are just held in with clips that you squeeze in and it pops out. Under that there is another 3 fixings to the main shunt bar, then you have a clip under each head lamp. You can either remove the whole lamp or do what i did which is slide a blunt dinner knife inbetween the bumper and the clip :cheers:
above is only for a standard bumper if yours is aftermarket then it may be differant as fixings are differant depending on who fitted it
1 - 3 of 3 Posts
