Forum Gypo
MPS & JDM Power are both reputable adresses, can't tell you much about Sky Engineering though, sorry.
Question, What do you need then?
Greetz Tony
I just finish my engine rebuild and I need to tune it the spec are as follow for now :)
ECU: NISTUNE
CP Pistons
Eagle Rods
ACL Race Bearings Rods
ACL Race Bearings Main
ARP Studs
ARP Rod Bolts
ARP Main Bolts
Cometic 1.2mm Head Gastek
N1 Water pump
N1 Oil pump
Crank Collard Mod
Supertech hydraulic Spring Kit
Supertech Titanium Retainers
Supertech Iconel Exhaust Valves +1mm
Supertech Intake Valves Nitride Coated +1mm
Valve Seats
Valve Seals
Valve Guides
Nismo Thermostat
HKS Blow Off
HKS Oil Cooler with Thermostat
Walboro 255lph High Pressure Fuel Pump
Deatschwerks 800cc Side Feed Injectors
Aeromotive Fuel Pressure Regulator
Aeromotive Fuel Filter
-6 AN Fuel Lines
Competition Stage 5 clutch kit
Competition Clutch Light Flywheel
AEM Wideband
AEM Boost Controller
Garrett GT3076R- T3 - .82 A/R
Precision 46mm Wastegate
3" Exhaust
3" Apex'i Intake
Z32 AFM
Front Mount Inter-cooler
Moroso Breather Tank/Oil Catch Can
In 2 to 3 months I will have a custom top mount manifold twin scroll and the new GTX3582R twin scroll, AEM Water and Methanol Injection, Tomei 260 cams with adjustable Exhaust cam pulley. Then I will run dual Walbro or the Bosch. And Q45 AFM.
Forum Gypo
Why not ask RXXXIV or Baros777 if you can get on one of the RSP mapping sesions?
There is a set date now and it´s in this section too! But looks like you could be late already...
