1 - 20 of 20 Posts
100% AWESOME BLOKE
I no this has Probably been talked about before but I just interested in getting a rough price on converting my n/a spec 1 33 2a turbo?don't want no uprated parts to start with just standard.
Any help would be great
Chris
i don't know the prices but heres alist to start with,r33 gtst bits,ecu,exhaust manifold,turbo,oil and water feed and return pipes ,downpipe,gaskets,intercooler+pipework airbox or aftermaket air filter,injectors and you need to look if you have an turbo oil return bung its on the block underneath where the turbo would sit,aftermarket boost gauge would be good
100% AWESOME BLOKE
cheers mate
bin given a couple quotes around the £550 mark seems reasonable and as there just bolt on mods i might try crack it myself then just go in for the remap...
was your liner a n/a before?
100% AWESOME BLOKE
i was thinking that mate but atm im looking at £1000 (roughly) to turbo mine and it will be able to run up to 350bhp which for me personaly is more than enough after that it just starts getting hectic.lol.
i dought i will be able to find a gtst engine AND get it fitted for £1000
chris
yes mines an standard na rb25de,just bolted some goodies ,i started out with a standard turbo and intercooler,ecu from a gtst then kept going,but stopped for now because of being made redundant,can't waste money on toys
about £400,i got all the bits from a chap on here which put a rod through the block was about 4 years ago and fitted it all on my christmas hols 4 years ago nearly and never looked back,the rb25de+t is a better drive less turbo lag especially when your in the 400bhp range,oh you'll need a resirc valve or bov
100% AWESOME BLOKE
Discussion Starter #13
thats good mate the prices keep on plunging mate its the fitting thats the most expensive now...dont wanna do it myself as probably never finish it.lol.
i figured id need a bov....really want wastegate chatter.lol
Mine cost me about £1500 to do including the map , james at innovate performance helped with mine and done the mapping he was near brands hatch . Have a look at my project it mite help you or pm me any questions and if i can help i will
I was looking into this too, what's the difference (if any) when you do the same conversion on the NEO RB25DE in a 1999 R34?
There is a guy on skyline australia that has do one i think his name on there is dan666 its a old thread but its the one i used when i done mine , good luck
tanner drop me a pic of the wheels and I might be able to help. Mrs is buying me megasquirt system for xmas so i'm turboing my measly 2ltr n/a as well
So, what needs to be swapped/changed then (not added to engine or the very obvious things like "fit a turbo huhuhu" :p)
Pistons (is high comp, 9? Swap to low, 8,5?)
Injectors (is? Swap for, 444cc?)
Ecu (swap for turbo one, what about cables to ecu? Any more values/gauges [except boost, but ecu dont care about boost anyway right])
Could swap to turbo plenum (apparently they arent the same)
What about AFM
Anything more? Sensors?
My problem is that my last skyline is a gts-4 so swapping for a regular rb25det wont work :)
And someone already converted to turbo and burnt a piston :D so now i need to figure out what he didnt do while i fix the engine ;) ( i already know there are high comp pistons in it, mistake #1 )
Sent from my GT-I9000 using Tapatalk
Car work on a budget, a very SMALL budget :(
If you need a standard R33 side mount intercooler I have one sat in a box in my house...
1 - 20 of 20 Posts
