Sorry for the essay but wanted to give as much detail as possible.
Fitted the R33 turbo today. As per my last thread, filled turbo and block with oil, topped up coolant, cranked over a good few times, fired it up for a min. Stopped, topped up oil. Ran it for 20 mins observing for leaks, none visible, topped up coolant and opened the nut on the front of the plenum until it was bled and full.
Just been out for a short drive - about 6 mile round trip to get petrol, only put my foot down once before stopping for fuel. All seems good.
On the way there water temp needle didn't start to climb til about 5 mins driving then jumped up to about normal, coinciding with a small bump so thought maybe a loose connection. Quick check for leaks at the garage , checked coolant - all looked good.
As soon as i start back, temp needle goes up to slightly over 3/4 - still nowhere near danger levels. I slowed right down and kept my eye on it and it dropped a bit to only a touch higher than norm. Got back and notice a whisp of steam coming out of the bonnet. Opened up and a lot of bubbling going on and rad pipes are rock solid. Opened up cap and there is a LOT of pressure in there! Took about 5 mins to calm down.
Any suggestions? Really hoping i haven't cooked the headgasket
