Poo. My turbo is on its way out. On slightest bit of boost you can hear the blades make a flapping noise. No Good. It is a standard tubby. Is there any way to disable the turbo to save my internals while i wait for a new tubby to arrive?
Cheers!
cant stop the turbine from spinning... but u can prevent it from boosting above about 5 psi. remove the vacume line connected to the dump valve and plug it. should keep boost below 5psi. and try not to get in boost. i have a good turbo and i normally stay out of boost during normal driving.
cool. cheers guys. a new tubby should be here any day now ready for a hybrid rebuild.
