hi all
any body can tell me if this is ok to use
GARRETT GT3776 TURBO GT37 JOURNAL BEARING 500HP 84 TRIM
Journal bearing turbocharger
Oil-cooled bearing system
High Load Capacity GT Journal Bearing System
High performance BCI-18 compressor and UHP turbine
4-bolt turbine outlet flange
T3 turbine inlet flange
POWERRSHIFT
Horsepower 320 - 500
Displacement 2.0L - 4.0L
SPECIFICATION
COMPRESSOR
WH DIA IND: 55.0MM
WH DIA EXD: 76.2MM
TRIM:52
A/R: 0.54
TUBINE
WH DIA: 72.5MM
TRIM: 84
A/R:1.12
TYPE: Free Float
which one
to use for my car
its a r33 gts-t and has any one used the e bay shop jne power outlet
lemsp
POWERRSHIFT
SPECIFICATION
COMPRESSOR
WH DIA IND: 55.0MM
WH DIA EXD: 76.2MM
TRIM:52
A/R: 0.54
TUBINE
WH DIA: 72.5MM
TRIM: 84
A/R:1.12
TYPE: Free Float
which one
to use for my car
lemsp
