Have just fitted a new Turbo XS BOV. What a noise!!!!
Some times the engine just cuts out if I stop quickly. This happens a lot at traffic lights.
Am I right in saying that the valve is staying open to long and sucking air in, therefore bypassing the air flow meter causing the revs to drop and cutting out.
Any Help Please.:mad:
Sorry to say Buzz, but you should have asked or done a forum search before you splashed yer cash, its a well known problem, these cars need a recirc BOV.
Only answer is probably an EIDS, least thats what I think its called, electronic idle control HKS type of thing, someone less tired than me will post to confirm I expect.
Why a recirc type?
Does it make a difference then apart from the noise?
because the air is recirculated back into the system, the airflow readings are still correct I believe
