Tyre pressures i am running 19'' wheels on my r33 gtst what pressure an clues?
also i have been told you can reset the ecu by disconecting the battery and pressing the brake pedal a few times and then taking it for a blast any truth?
thx:uzi:
confused.com
tyre pressure... manufatures recomendations should be onthe tyre. i have noticed that cos the tyres are so small (i run nineteens too) the steering is really sensetive to any change in pressure so keep an eye on em regular for any loss.
i run mine at 35psi a corner. and it feels ok ...may change that when i get spacers i'll see how she feels.
(kuhmo tyres 235/45/19)
as for the ecu yes thats true if you have a factory standard ecu ..get the car nice and warm and then reset it by disconecting power, (battery) and pumping the brake gets rid of any residual charge .(alledgedly) or alternatively leave for an hour.
then reconect, go fill with v max and drive it so the ecu can "learn" your driving style and set fueling acordingly.
