Anyone any idea what tyre pressures should be for an R34 GTT with 235/45/18's on the front and 265/35/18's on the rear.
I'm using 32psi on 265, 35 x 18's on my GTR. I've been told that's right, and I haven't had any handling or tyre wear problems.
Paul
Discussion Starter · #4 ·
Cheers folks.
Pressures are currently 33 all round - think I'll leave it be for the time being.
I think 33 is correct. The original tyre pressure should be written on a white label with green writing, its on inside drivers side door frame. The pressure specified will be (for Japanese imports like the GT-T) in bar so you need to convert bar to psi. This gives 33, if you lower the profile you may need to adjust the pressure slightly higher -
Also be aware you speedo will be slightly out on bigger rims) so you should be very careful about speeding as you may be going faster than you think!
Cheers,
T
