1 - 20 of 41 Posts
Australia Area Rep
I came across this guide for the Apexi Power FC and found it very useful
so i thought i'd share this with everyone
I forgot the website link i got it from but i did manage to save it to a word document so if anybody wants the guide with the pictures then pm me and ill send it to you
I've had to make seperate parts for it aswell because the forums got a 1000 character limit for each post
ENJOY! :)
PART1
Apexi PowerFC FAQ - Frequently Asked Questions
Unit Information
1. What does the unit do?
2. What cars is the PowerFC supported on?
3. What cars is the PowerFC not supported on?
4. What does the unit look like?
5. What are all the menus and functions on the unit??
6. Is there a menu roadmap?
7. Does the unit work on my N/A car?
8. Does the unit work on manual and auto cars?
9. How much does the unit cost?
10. When I buy the PowerFC what comes in the box?
11. Why would I want to buy a PowerFC?
Model Information
12. What model do I need? (Version Matrix)
13. What is an "AP Engineering model" and do I need it?
14. What is the "D-Jetro" model and do I need it?
15. What is the "Power FC Pro" model and do I need it?
16. What other optional parts are available for the PowerFC?
17. Is the PowerFC Pro Discontinued?
18. Hybrid Apexi PowerFC models and mix n match models, can it be done?
19. Apexi LJetro Vs Apexi Djetro - Whats the deal??
20. Apexi PowerFC Djetro PRO - Does it exist???
21. Why buy a PowerFC? Aren't they discontinued????
22. What's the Apexi D1 Limited Edition Hand Controller?
23. Is there an English manual? a PDF copy? English translation?
24. I have the older PowerFC that did not come with a hand controller can I buy a new hand controller separate and use that?
Considerations before use
25. Does the PowerFC run the whole car or do I need controllers for... (Aircon, Lights, ABS etc...)
26. Does the PowerFC have limits?
27. What are the basic mods I should have when I get my PowerFC
28. Are there any cool tricks with the PowerFC? Free mods etc?
29. How does the PowerFC compare with the Apexi SAFC, AVCR and other Apexi computers?
30. Apexi SAFC vs Apexi PowerFC, whats the difference?
31. How does the AVC-R compare to the PowerFC boost controller kit?
Installation
32. How do I install the PowerFC?
33. Basic Hand Controller functions and use
34. Help! My car doesn't start once I've installed the PowerFC
35. Once the PowerFC is installed can I expect any better performance or does it HAVE to be tuned?
36. Can I drive around without it being tuned for a few days? Months? ?
37. Help! My car doesn't idle once I've installed the PowerFC
Basic Operation
38. Basic Hand Controller functions and use - Monitoring
39. Basic Hand Controller functions and use - Checking Functions
40. Basic Hand Controller functions and use - Checking Sensors
Advanced Operation
41. Are there any hidden/secret features? Stuff you can't access by the Hand Controller
42. Does the PowerFC have any laptop hook up options or software
43. What does the PowerFC support in terms of modifications?
44. What do I need to do when changing my Airflow Meter
45. How do I configure larger injectors?
46. How do I setup a larger scale map sensor?
47. PowerFC Pro - Launch Control
Advanced Operation - Optional Kits for the PowerFC
48. How do I hook up the optional Boost Controller kit?
49. How do I configure the optional Boost Controller Kit?
50. How do I hook up the D-Jetro Map Sensor Harness Kit?
51. Replacement or upgradable Map Sensors for the Boost Control Kit / Djetro Kit?
Tuning Information
52. Where can I get my PowerFC tuned and how much will it cost me?
53. Can I tune the car myself?
54. What is Map Tracer? Is it useful?
55. My fuel economy is terrible and I just had a complete tune, Whats wrong?
56. Self Tuning - Ignition Timing
57. What are the percentages for my airflow voltages for?
58. Is there a way or guesstimation to calculate AFR's based on the INJ values?
59. I always have knocking, is it true, is it lies or is something wrong?
60. How do I debug knocking, how can I make it go away?
Technical Issues
61. What do the strange sensor names mean?
62. Why does my engine light flash when I drive with the PowerFC
63. My idle is really crappy and it hunts around a lot when on idle. What can I do
64. I am seeing on my Map Tracer that I am reaching load point 19-20 on full throttle. I am maxing out the PowerFC! What can I do
65. When I turn my car off I loose any changes on the PowerFC! Help!!
66. When I turn my car on I get a clicking relay noise and the hand controller dies
67. My car won't start when I plug in the PowerFC, but the stock ecu works fine
68. My Skyline R32 GTR has a wierd misfire problem, what's wrong?
69. I have fried my PowerFC. Is it fixable?
70. My Hand Controller freezes at the Apexi Logo. Why???
Unsupported Features
71. Airtemp sensor on unsupported car?
72. Boost display without the Boost Control Kit?
73. What does the PowerFC look like inside?
74. Can you reflash the PowerFC with new code and/or different versions of the Apexi code?
75. Are there any cool custom hacks, hand controller holders, DIY rewiring you can do?
76. Is there a replacement hand controller screen?
77. Can I use 95ron octane fuel (non premium)?
78. Poor mans antilag??
79. Boot up diagnostic??
80. Can I have a lumpy 'cammed' idle?
81. Ford Falcon XF Throttle body with the PowerFC
82. Piggybacking the PowerFC with another ECU
83. I want to go EPROM/Firmware hacking, Tell me how
84. Replacement Air Temp sensor?
Datalogit System
85. What is Datalogit?
86. What does Datalogit do, is there a feature list?
87. What does the box look like and what's inside it?
88. Do you really need to have it or is the Hand Controller OK?
89. Where did you get it from and can I buy one? What is support like?
90. Datalogit Yahoogroups!
External Resources
91. Car Forums - New Celica - Advanced Datalogit Tuning
92. Car Forums - RX7Club.com
93. Car Forums - Evolutionm.net
94. Apexi PowerFC Wikipedia
95. Datalogit Yahoogroups!
Notes
96. Autospeed review of the Apexi PowerFC
97. A Note about the PowerFC FAQ
98. A Note from the author
99. Apexi Officially Bankrupt
100. Change Log
________________________________________
The unit is a full replacement ECU for your factory computer. It is not a piggyback system and as such allows full control of the engine and computer controlled systems. It comes with a base map of your cars computer with base map tuned for basic mods such as exhaust, boost controller, air filter upgrade. "The Power FC is a complete, stand alone, total engine management system capable of handling virtually anything thrown in its path." - www.apexi-usa.com
Return to the Index
Standard Versions
• Honda Civic Type R 97/6-98/8
• Honda Integra Type R 95/9-01/6
• Mazda RX7 Series 1-3 91/12-95/11
• Mazda RX7 Series 4 95/12-98/12
• Mazda RX7 Series 5 99/1-00/9
• Mitsubishi Evo V 98/1 - 98/12
• Mitsubishi Evo VI 99/1-01/1
• Mitsubishi Evo VII 01/2 - 02/3
• Mitsubishi Evo VIII (EVO VII PFC + 4E73G013 EVO VIII Harness) - VIII MR might not be supported
• Nissan RPS13 (Black Head) 94/1 - 96/7
• Nissan RPS13 (Black Head) 96/8 - 99/1
• Nissan RPS13 (Red Head) 91/1 - 93/12
• Nissan S13 Red Top 91/1 - 93/9
• Nissan S14 93/10 - 96/5
• Nissan S14 96/6 - 98/12
• Nissan S15 99/1 - 02/7
• Nissan Skyline BNR32/BCNR33
• Nissan Skyline BNR34
• Subaru WRX Ver1,2 92/11-96/8
• Subaru WRX Ver3,4 96/9-98/8
• Subaru WRX Ver5,6 98/9-00/7
• Totoya Mark II, Chaser & Cresta JZX100 manuel 96/9-01/7 1JZ-GTE
• Toyota Altezza SXE10 01/5 3S-GE
• Toyota Altezza SXE10 98/10-01/4 3S-GE
• Toyota Celica ZZT231 99/9 - 2ZZ-GE
• Toyota Mark II, Chaser & Cresta JZX100 Automatic 96/9-01/7 1JZ-GTE (Mark II only to 00/9)
Djetro Version
• Mitsubishi EVO V CP9A 4G63 98/1-98/12
• Mitsubishi EVO VII CT9A 4G63 01/2- 02/3
• Nissan 180SX RPS13 91/1-93/12 SR20DET (Red Head)
• Nissan 180SX RPS13 94/1-96/7 SR20DET
• Nissan 180SX RPS13 96/8-99/1 SR20DET
• Nissan Silvia PS13 91/1-93/9 SR20DET(Red Head)
• Nissan S15 SR20DET 99/1-02/7
• Nissan Skyline BNR32/33 89/8 - 98/12
• Nissan Skyline BNR34 99/1-02/8 RB26DETT
Australia Area Rep
Discussion Starter #2
Part 2
Vehicles such as the Nissan Stagea are not supported however the Stage features a Skyline engine (either rb25de, rb25det, rb26dett) engine and standard computer, so a suitable PowerFC for same engine year/model *should* work fine engine/computer.
The Apexi PowerFC is purely an injector and ignition driver but is it suited around specific car models to suit their sensors and control signals. It is possible to make it work on other unlisted models or cars but it would require extensive re-wiring and/or sensor matching to make it work.
Vehicles such as the Nissan Skyline R33 GTST that feature the Active-LSD or A-LSD and SLIP function (lights on the dash and vspec diff) will suffer A-LSD compatibility problems. The car will operate correctly and the diff should as well however you will experience "A-LSD" error/failure intermittently. To date there is no known solution for this problem. It appears to be only present on the R33 RB25DET. There was a limited run of R33 known as the GTS25TML spec which is the M Spec with Active LSD. The diff is a skyline GTR vspec diff, electronically controlled LSD instead of a normal R33 diff. It features the same finned cover and A-LSD function as the Skyline GTR. The A-LSD and SLIP functions in the Skyline GTR with the Skyline BNR33 PowerFC work fine, only the ECR33 with ECR33 PowerFC is affected. See here for some discussion on the topic.
There is now an unofficial Fix for the A-LSD problem found in the ECR33 Skyline. Please click here to view how to fix it; Link
Return to the Index
The PowerFC looks and is usually in the same ECU case as the standard ECU for your car. This is because it needs to use the same car loom adapter, same brakets etc so its usually the same physical shell & bolt holes for the ECU braket. The hand controller is a lightweight and ergonomic device with a backlit LCD screen. The screen is larger enough for most tuners and owners to use and operate. It includes enough functionality from the 4 main buttons and PREV and NEXT to control the car, make changes, update the tune etc. I would recommend all owners buy the PowerFC with the hand controller - It is very basic without the hand controller and you can't update/change anything.
This is the ECU and hand controller
This is what the settings screens look like
This is the unit's plug layout
Return to the Index
Here is a function list of all available options from the Hand Controller.
This is for every PowerFC version so you won't have some of these on your Hand Controller.
Note: Some items are not avaiable on various units (ie: PimVolt only on DJetro and Map Sensor versions)
Note: Some factory items do not work - Airtemp on R33 GTST
MONITOR
AirTemp - Air Temperature
Airflow - Airflow Meter Voltage
BatVolt - Battery Voltage
Boost - Boost Pressure (Bar)
Eng Rev - Engine RPM
IgnT Ld - Ignition Leading (Rotary only)
IgnTmng - Ignition Timing
IngT Tr - Ignition Trailing (Rotary only)
InjDuty - Injector Duty
Knock - Knock Sensor
PimVolt - Map Sensor Voltage (DJetro only)
Speed - Speed KM/H
WtrTemp - Water Temperature
SETTING
Acceler. - Acceleration Enrichment
Airflow - Airflow Meter Voltage Table
Cranking - Cold Start Cranking Table
IGL Map - Ignition Leading Map (Rotary only)
IGT Map - Ignition Trailing Map (Rotary only)
Ign Map - Ignition Map
Ign/Inj - Ignition and Injection Temporary Adjust
Inj Map - Injection Map
Injector - Injector Latency
Pim Volt - Map Sensor Voltage Table (Djetrol Only)
Rev/Idle - Rev and Idle Settings
Wtr Temp - Water Temp Correction Table
ETC
Prog. Version - Display PowerFC and Hand Controller version
Sensor/SW check - Sensor check page
Function Select - Function Select
02 F/B Control - O2 Sensor Feedback Control - Open/Closed Loop
Airflow Warn - Airflow Meter Warning - 5v Peak (Engine check light)
Boost Cntl Kit - Apexi Boost Control Kit
Idle-IG Cntrl - Map Sensor Idle Logic (Djetro only)
Injector Warn - Injector Warning (Engine check light)
Knock Warning - Knock Sensor Warning
LCD/LED adjust - Backlit display contrast adjust
All Data Init. - Reset to Factory Defaults
Apexi went to great lengths to ensure you could control everything that a tuner would need with minimal fuss.
The interface is very intuitive and easy to use. It appears as they didn't opt to include un-needed/un-necessary things such as monitoring oil pressure from the hand controller, oil temps, and other sorts of "nice to have features".
As these would add development cost, extra sensors etc. The unit is a very efficient plug and play unit for a very cheap and affordable price. Extra junk just adds development cost, which increases the price. So basically everything you need is via these menu's.
Return to the Index
For a menu road map check out the following picture, coutesy of Autospeed:
Return to the Index
It has been rumored the work with unconfirmed reports. The model however is still suited for the turbo version of the engine so timing, ignition, maps etc may be unsuitable. There are a few N/A PowerFC versions for the Honda etc so they do exist, its just more common for the turbocharged model
Australia Area Rep
Part 3
The PowerFC only supports manual cars (excluding Toyota). It will work on an automatic car however it will not handle gear changes and simply keep the throttle nailed during a gear change. This will result in jerky gear changes and stress placed on the gearbox. The factory ECU during a gear change will communicate with the auto box and drop timing, ignition to ensure a smooth change. For those wishing to use PowerFC with auto you should consider a mechanical auto gearbox instead of an electronic. The PowerFC should work fine with a mechanical gearbox such as power glide, transbreak etc.
This is because the mainstream ECU's in Nissan etc rely on the main cars' ECU for gear logic change control and functions. Cars such as the Toyota have a seperate ECU for the gearbox change logic and control so it's not affected. Apexi chose not to port the Automatic gearbox logic code (as its very long and complex) into the PowerFC because I suspect they found its simply not worth it & too complicated. You can buy an Automatic PowerFC for a Toyota Chaser for example and it has auto logic control under SETTING, you can set the shiftmap, ramp up speeds etc as it has the code to interact with the Toyota AUTO ECU that is seperate to the main ecu. So in summary - Auto PowerFC's exist & work but only for Toyota. We have seen quiet a few Auto R33 Skylines with manual PowerFCs - some report they work fine etc and there is no difference - do so at your own risk.
Return to the Index
The unit currently retails around $900 AU delivered from Japan for a new unit. However as Apexi have altered their production plans this only applies to some select models. Other models must be sourced 2nd hand from forums, ebay, other members etc. For AP Engineering models they are more expensive as they are a custom made model and retail is around $1500 AU or even higher. Recent pricing indicates around the $920 mark is more realistic. There are some workshops or resellers that list they have the "Australian" version of the Apexi PowerFC. This is simply the same PowerFC but sold with an Australian delear or reseller warranty. Normally your PowerFC needs to be sent to Japan for a warranty claim and/or testing. With an "Australian" version it can be done locally supposedely.
There are also unconfirmed rumors of the local distributors being able to supply the latest firmware for the PowerFC. To date the latest firmware I have seen on ECR33 is 5.11 which was from Mid Oct 2006 build. The price of the "Australian" PowerFC is somewhere near $1500 so its not even worth the cost, given the mean time between failure of the PowerFC's. Basically if it fails, you've done something wrong or have a dodgy wiring loom / hacked up loom.
Lately it seems everyone is cashing in on the "discontinued" situation that the PowerFC is in.
The main models are still in product, its just slower and takes longer to get one on order new from Apexi.
I would be careful in how much you pay for a PowerFC these days. I have seen upwards of $1600 AU for a used unit these days on Ebay.
The places I would look for 2nd hand PFC's would be your local car club, Ebay and Yahoo Japan auctions (lots on here usually).
Return to the Index
The current PowerFC comes with the following items
• Apexi PowerFC ECU
• Apexi PowerFC Hand controller
• Apexi PowerFC Japanese Manual
• Apexi PowerFC Japanese Warranty Card
• Velcro Sticky tabs for use with the Hand Controller
This applies to new units purchased. Previously the older style new units were the main ECU only.
Some time around 2004 ish Apexi decided to bundle the hand controller and ECU as one main price.
Return to the Index
An outdated english manual (for the RX7) is available at English Commander Manual.
The current Japanese manual can be found at Japanse Command Manual (updated)
For a complete Japanese Manual matrix on the Apexi site go here: http://www.apexi.co.jp/manual2/pdf/torisetu_p_fc.html
Japanese Manuals (high quality PDFs)
Name Link
PowerFC Manual 3SGE Right click, Save as
PowerFC Manual RX7 Right click, Save as
PowerFC Manual Nissan (180sx, 200sx, GTST, GTR) Right click, Save as
PowerFC Manual Evo Lancer Right click, Save as
PowerFC Manual Evo Lancer DJetro Right click, Save as
PowerFC Manual MR2 Right click, Save as
PowerFC Manual 180SX Right click, Save as
PowerFC Manual SR20 Right click, Save as
PowerFC Manual Honda Integra Right click, Save as
PowerFC Manual Skyline GTR Djetro Right click, Save as
PowerFC Manual Chaser JZX100 Right click, Save as
PowerFC Manual Subaru WRX Right click, Save as
Return to the Index
You may be able to depending on the version of the ECU and hand controller. If the version between the ECU and Hand Controller is different the Hand Controller will boot up the Apexi logo and freeze. Take this as a precaution as a few people have experienced this. If you experience the hand controller freeze problem click here to get some help on it.
Pay attention to the version matching and you can't go wrong. Your local supplier can order the correct hand controller for you. If you can't find a supplier http://www.nengun.com/ can source the older styler and newer style hand controller (N001 and X001) for you new at a new price. If you are after a 2nd hand unit you can try Yahoo Auctions, Ebay or even Jap Parts at http://www.jappartsspecialist.com/
Return to the Index
Version Matrix
Version Alternate names? Input Type Extras
Standard LJetro or just normal PowerFC Airflow meter normal unit
Djetro Map Sensor PowerFC Map Sensor normal unit with map sensor input instead of AFM
Pro FC Pro - PowerFC Pro AFM Launch control (0km/h limiter) & Spark cut (instead of fuel cut) at limiter
AP Engineering AP Eng AFM usually These are remapped PFC's to suit extra cars (ie R33 RB25 GTST PFC remapped to suit R32 RB20 PFC)
You cannot mix and match models - Some cars only have access to some models etc. ie: There is no Djetro version for R33 GTST - There is no Pro version of Evo 8 etc. Apexi release some models in all 3 flavours to suit the market (Skyline GTR gets all 3 options). Some models can be back ported to other cars ie: R33 GTR can work on R33 GTST so you can have R33 GTST Djetro (and Pro etc). Some AP engineering releases can be Pro versions too. There are some counterfeit FC Pro versions out there (buyer beware).
Click here to read up on the PowerFC Djetro Version
Click here to read up on the PowerFC Pro Verion
Click here to read up on the PowerFC AP Engineering Version
You should note that all models are now discontinued other than standard Ljetro versions. Apexi no longer make Djetro, Pro or AP Engineering versions. You need to source these models 2nd hand from Ebay / forums etc.
Return to the Index
"A.P. Engineering Original Power FC units carry the same functions as the regular Power FC units but have been specially adopted for use on car models that the regular Power FCs do not cater for. As they are an item outsourced from Apexi, their pricing is higher than the regular models." - www.greenline.jp. An example of an "AP Engineering" model is the PowerFC for the r32 gts-t.
AP Engineering versions are no longer available brand new. You need to purchase one second hand if you want to buy one
Australia Area Rep
Part 4
The D-Jetro Power FC units carry the same functions as the regular Power FC units but do not require the use of the factory standard air flow meter and use a mass air pressure sensor. Apart from the unit itself, use of the D-Jetro units requires additional parts that vary depending on the model." - www.greenline.jp The airflow meter (at least in the skyline range) does not pose a big restriction in terms of horsepower and one would doubt the use of the D-Jetro. If you really need massive airflow you can always change to 2 x Q45 Airflow meters and use those with the PowerFC. The skyline series are optimized for closed loop operation with an airflow meter.
The Djetro version has a few caveats you should know about before you consider using it
• Careful placement of the map sensors in multiple throttle body systems With multiple throttle bodies, such as the Skyline GTR RB26 or the Pulsar's GTI-R SR20 multiple throttle bodies can have bad side affects when using a map sensor system. Consideration needs to be taken into account when placing the map sensor (or map sensors) for the Djetro system to avoid idle problems on multiple throttle bodied engines.
• Tuning will take considerably longer It will take considerably longer to tune a Djetro PFC over a normal LJetro PFC. This is because all of the work has to be done from scratch instead of just doing the main bits in the AFM/LJetro version. You should discuss this with your tuner and find out the total cost for a Djetro tune.
Return to the Index
What is the "Power FC Pro" and do I need it?
The Power FC Pro Spec.CPU has been designed for drag racing use. These units have two additional functions over the regular units: 1. Ignition cut used for rpm limiter - Regular Power FCs cut fuel feed when the preset revolution limit is reached. At high rpm, there is the possibility of knocking when the fuel is cut in high-powered cars. The Power FC Pro CPUs cut ignition at the rpm limit to prevent the knocking that could potentially destroy the engine. 2. 0km/h rpm limiter setting - Allows for the setting for an initial rpm limiter that is active whilst the car is not in motion. This allows for mainting a rpm level for consistent launches.
PowerFC Pro versions are no longer available brand new. You need to purchase one second hand if you want to buy one. There have been reports or rumors surfacing of fake PowerFC Pro units that are just the normal standard versions. The true PowerFC Pro versions have some unique features which give them away.
Have a look at What does the PowerFC look like inside? to identify what a PowerFC Pro version looks like. The dead gives are the older style main board with the top mounted expansion chip (same as AP Engineering). The other dead give away is the "FC Pro XZXZX" sticker on the side of the main ECU case.
There should also be a sticker on the main ecu which would read something like "RB25PRO1" or "RB26PRO1". Under ETC, VERSION on the hand controller you should see a similar version string "RB25PRO1" or "RB26DETTPRO1" etc. It should definetly have PRO in the version string - There have been reports of people reflashing the Pro hand controller to normal FC code (don't see why u would?) Be sure to double check before you buy it to make sure its a legit PowerFC Pro version.
For some more discussion on the this topic check out gtr.co.uk;
Power FC Pro identification help
Return to the Index
The PowerFC emulates all the functions that your standard computer did. This includes things like Aircon, Lights, ABS etc.
What ever your car did with the standard ECU, it will do the same with the PowerFC.
Return to the Index
Here is an almost complete of optional parts for the PowerFC.
Note they do not work or plug into all models, some parts are Djetro only, some are Ap Engineering only etc.
Hand Controllers
Name Part No
Hand Controller (Old Style (To suit ENGINE MODEL STYLE PFC - IE: PFC RB25 or PFC RB26) & AP Engineering old style) 415-N001
Hand Controller (new Style (To suit CAR MODEL STYLE PFC - IE: PFC ECR33 or PFC GTR33L) & Multiversion hand controller) 415-X001
Hand Controller Toyota 415-T001
Hand Controller Toyota (JZZ30 only) 415-T003
Hand Controller Extension Cord (Make your own)
Name Part No
Hand Controller extension cord 60cm 415-XA01
Hand Controller extension cord 3m 415-XA02
Boost Solenoid Kit (To read and display Boost on the hand controller)
Name Part No
Apexi Boost Sensor (Boost Control Kit) 415-X001
Apexi Boost Sensor Harness (3 pin PFC) 49C-A002
Apexi Boost Sensor Harness (5 pin PFC) 49C-A003
Apexi Official Software (not recommended)
Name Part No
Apexi FC Commander Pro software 415-X010
There are other optional parts avaiable you just need to find the part numbers.
In actual fact I recently brought the Boost Control Kit in parts and found it cheaper in parts, I guess this is becuase of the way its shipped in a medium box.
Return to the Index
There are many reasons for changing to a PowerFC the most common being to extract more power from the current engine setup. Your cars factory computer has many limits and conservative settings to ensure engine reliability and to ensure factory components do not have excess load placed on them. As you upgrade these components the factory computer will not retune itself and therefore you will not obtain your maximum benefit. You can reset your cars ecu (works in most Skylines) and it will relearn your engine setup and adjust accordingly but that is only basic tune settings. There are much more advanced tune settings available with the PowerFC.
Return to the Index
The PowerFC does not have limits such as speed limiter or boost cut the factory ECU has to prevent engine stress / excess load. It has adjustable idle, rev limit and on-load idle. You can set your cars rev limit to whatever you like. 10,000rpm if you like.
There are no hardset limits in terms of power, killowatts, horsepower or turbo size etc its purely as good as your tuner. So if you have a good tuner then there is no logical/physical boundary etc. The Apexi 1200HP drag car uses a PowerFC for its main ECU (no surprise).
Return to the Index
A handy trick PowerFC owners use when they take car in for a service/work to be done they set the rev limit to 3000rpm and remove the hand controller. .This prevents the workshop from taking your car out for a fang on the roads and driving it like they've stolen it as the PowerFC will cut the power at the 3000rpm rev limit interrupting the joy experienced by the joy rider of your precious car. This would be useful at panel beaters, car cleaners, stereo installers etc. This would not suitable for a performance workshop cos if they are tuning your car or fixing a problem they may need to actually rev it out so use this wisely. Another unofficial mod is instead of buying the official PowerFC hand controller extension cord is to use a normal Ps2 extension cord used for a normal PC computer. Its the same cable you just need to break off one of the pins.
Australia Area Rep
Part 5
The Apexi AVC-R and SAFC are piggyback systems. The SAFC controls airflow voltage and fakes airflow voltage to the ecu. This makes the ecu believe more airflow is present and cranks up the fuel/timing thus resulting in more power. The AVC-R is a boost controller and not really a piggyback as such.
Apexi SAFC - Piggyback Fuel Computer
Apexi AVCR - Boost Controller
Apexi VAFC - Vtech and Piggyback Fuel Computer
Apexi Imoni - Diagnostics display from consult port
Apexi Multichecker - Diagnostics display from consult port
Apexi PowerFC - Standalone Engine Management
You can obtain the similar functionality from the AVC-R as you can from the PowerFC with the boost controller kit installed. The AVC-R and the PowerFC boost kit use the same solenoid and map sensor parts. It is confirmed that you can switch the AVCR solenoid and map sensor to the PowerFC boost kit but it should work. You can make the PowerFC display boost pressure without buying the Boost controller kit by buying the map sensor and using the Boost Kit Harness.
Parts list: What other optional parts are available for the PowerFC?
You will need:
• Map Sensor
• Map Sensor Harness
• Solenoid
The main difference between the AVC-R and the PowerFC Boost Kit is the AVC-R can do gear judge or predictive gear based boost control and it has the pretty blue screen. The code logic, solenoid parts, wiring etc is the same.
Disconnect your cars battery and discharge all power from the car. You can do this by unplugging the battery and pressing the brake pedal a few times. Locate your cars computer and unplug the factory car wiring harness. The harness is usually screwed into the ECU so you need a Phillips head to undo the bolt in the middle. Once you have removed the factory-wiring loom you need to remove the ECU from its brackets. You can simply unscrew it and pull the ECU out. Once it has been removed put it in a safe place in case you need to go back to your factory computer. Put the PowerFC in its place and plug in the factory wiring loom the same way it came out of the stock computer. Be sure to note which way the ECU came out and match the pins/wiring notation correctly. Once it has been secured with the holding down brackets/screws you are now almost ready to start your. Before you start the car for the first time you should give the ACC key turn power so the hand controller turns on. If you are not using the PowerFC boost controller kit make sure you disable this feature. Go to the "Etc" menu and choose "Function Select" and then choose "Boost Control Kit" and set the option to a Japanese character that looks like a plus sign. This will disable the PowerFC boost controller kit. The PowerFC manual states to start the car, ensure no errors are present and let the car idle for at least 30 minutes. During this idle period wait about 10 minutes, turn on the air con, wait another 10, turn on the demister, wait another 10 minutes or so and then your car is ready to drive. If you short cut the self learn idle procedure once the car is turned off and back on again it will simply stall each time. If this occurs you must factory reset it again and do the procedure from the st.art
• Disconnect Power
• Unplug stock ECU
• Plug in PowerFC ECU
• Reconnect Power
• Start Car, let it idle for approx 10 minutes before doing anything
• Turn on aircon, let it readjust its idle and wait about 10 minutes
• Turn on demister, let it readjust its idle and wait about 10 minutes
All done and you are ready to drive with your new ECU now. At this point you should familiarise yourself with using the hand controller and just checking the initial sensors and make sure the basic options are turned on and you know how to read the basic information.
Below is a list of things you should check before heading off to your tuner. These are just precautions and will make sure its ready to be tuned and avoid any silly problems at the start.
Installation Checklist:
Sensor Check
MAIN MENU, ETC, SENSOR SW / CHECK Look for any sensor names highlighted in BLACK background or any flashing sensors. Any highlighted in black indicates a problem. The engine check light will also stay on if any of the sensors aren't working (highlighted in black). This is not to be confused with the black DOT switch on / off sensors.
Stable Idle
The car should have a stable idle and shouldn't hunt. If it is hunting (revs bounce up and down a lot) and you can hear the engine "hunting" then you should consider a re-initialize and self idle learn again. If you don't have stable idle the car will be sucky and frustrating to drive.
Engine vitals OK
MAIN MENU, MONITOR, 8 CHANNEL,
Select the following
• WtrTemp
• Knock
• BatVolt
• Airflow
• EngRev
• InjDuty
• Boost
• IgnTmng
WtrTemp when the engine is warm and stable should be around 70 to 80deg.
Knock at idle should be 0 or like 1 or 2 at the most. Give the engine a few revs, ensure it returns to zero.
BatVolt should be around 14 at idle. Too low is bad and Too high is bad. over 15 is bad and under 14 can also be bad.
Airflow should be stable at idle, around 1100mv (millivolts). Should increase when you give the engine a rev and should return to around 1100 ater it returns to idle
EngRev should be similar to what the stock tacho says, it may be out a little bit. Ensure it follows stock guage when you give the engine a rev.
InjDuty should be around 1 to 2% at idle and should increase considreably when you give the engine a rev.
Boost (if not using the boost kit it will be ---) should be around -500mmhg at idle and should goto near 100mmhg with a free rev.
IngTmng at idle should be around 15 or 20deg. Should increase considerably with free rev.
No engine check list or exhaust temp light
The cars factory engine check light or exhaust temp light should NOT be on. If this is on or flashing it indicates a sensor problem. See the "Sensor Check" section on what to look for to identify the faulty or wrong sensor.
Restart the car a few times to ensure its stable
Restart the car a few times to ensure engine check light doesn't come on and idle is stable
Australia Area Rep
PART 6
Check that you've disabled the PowerFC boost controller kit in the step above. Check that you've chosen the right model PowerFC. Check that you've securely fastened the wiring loom and its not loose. Some cars only (for some strange reason) have half gauge wiring running from the battery to the ECU. This works fine for the factory computer but the PowerFC needs the full 12volts. You can simply run new 12volt wire from the battery to the ECU and this should correct this. This problem has been experienced by at least two members previously (both in R33 GTST) If the hand controller displays the Apexi logo and freezes then you have the wrong hand controller version or its damaged. If you find your car cranks, starts and stalls immediately you should check you have entered the correct injector and airflow meter settings (if they aren't standard items). If you still do not have a stable idle follow this procedure <
• Turn car off
• Turn car to ACC
• On Hand Controller, ETC, DATA INIT, YES
• Turn car off
• Turn car to ACC
• Change AIRFLOW and INJECTOR as needed (if different from stock)
• Turn off Boost Control Kit (if not being used)
• Start car and follow idle procedure
Failing that take the car to a mechanic/tuner who has worked on the PowerFC and see what they can sort out for you. It's pretty rare for a PowerFC to not start first shot - so double check the list, ensure you have done a DATA INIT on it and restarted the car etc before going further.
Does the PowerFC have any laptop hook up options or software?
The PowerFC has an official laptop software hookup but it is only for Power Excel workshops. These are workshops endorsed by Apexi and they will not give out the software. You can now purchase the official PowerFC Cable and Software for around $550 AU. This includes the official cable and PowerFC software. The Software is in japanese and so is the manual. There is an unofficial product called the FC-Datalogit. This is a 3rd party product that includes a dongle/serial cable and software. It's retail is around $520 AU and supports full control of the system just like with the hand controller and supports logging to your laptop for replaying and viewing later. You can also make your own cable/dongle providing you know how (and have the PIC processor code). The diagram on my site needs PIC processor code to work and this code is NOT avaiable, is it not released for public use, please do not ask for it. Should cost around $50 in parts, then you can use the PowerFC Pro (if th cable works) software from my site. There is a new product on the way due for release in August which is the FC Tune. This appears to have the same functionality as the datalogit however it supports all of the cable types including a custom made one. Retail is rumored to be around $299 USD for the cable. The software is free.
• Apex'i FC Pro Software and Cable (retail product)
• FC Tune and Cable
• Datalogit FC Edit and Datalogit Connector Box (retail product)
• Kashima's custom cable (needs PIC processor code)
You should read here if you are intersted in Datalogit
Are there any hidden/secret features? Stuff you can't access by the Hand Controller?
If you have the PowerFC cable and software or the datalogit kit you can get to a few features that arent supported on the hand controller.
• You can download maps to your PC and save them.
• You can set the fan temperature turn-on value to below lower then 60deg.
• You can set the millisecond values for the engine flash light for AFM, INJ, KNK levels.
• You can access and control the air temp correction table.
• You can adjust load map points by extended the airflow measure levels.
The follow tables/settings are also changeable
• Inlet air temp fuel map
• Water temp fuel map
• RPM acceleration fuel map
• Cranking Injector dwell map
• Water temp versus boost fuel correction
• Inlet air temp versus boost fuel correction
• RPM Load Point table
• AFM load point table
• AFM voltage table
• Ignition versus water temp correction
• Ignition versus inlet air temp correction
• Ignition dwell versus RPM correction
• Ignition versus battery voltage correction
• Ignition versus boost correction
• Individual injector trim
• Injector lag versus battery voltage correction
The following functions can be supported by additional hardware with Datalogit
• Antilag via injection
• Antilag via ignition
• Intercooler spray
• A/C and non A/C overheat fan temp switch.
• Every standard sensor is logged
• Optional logging for (lambda, brake temperature, suspension travel etc)
The PowerFC has a map for inlet air temperature which is not accessible by the Hand Controller but the table is still used by the PowerFC if it picks up Air Temp from the factory sensor. The Skyline RB26 has this sensor and the stock GTST loom can be adapted to support this sensor and allow the GTST PowerFC to read the value.
It is always recommended that you get your PowerFC tuned for your cars mods. This will take into factor things like a lazy fuel pump etc that will be missed with just the factory tune. A full tune will ensure your A/Fs are safe and the engine is not excessively knocking and you are getting maximum benefit from the new ECU. A standard map will have benefit over the stock computer as it wont have built in limits the factory computer has and it also controls things like Variable Valve Timing better (on r33 RB25det at least) and provides more torque in the rev range without a tune.
You can drive the car around as you would normally but you should take care not to put stress on the engine. Basically don't fang around in it, as you could be running unsafe A/Fs etc and just causing more damaged. Best to get it tuned. Make sure you watch the knock levels if you do this to make sure there isn't excess detonation.
The PowerFC can support bigger injectors, larger turbos, aftermarket plenums, superchargers, nos kits, etc. The PowerFC is able to do this by allowing the tuner to adjust all the parameters of the engine on a load vs. rpm map for each of the core components. You can tune the computer to run xyz amount of fuel at 2300rpm on load xyz and to have xyz timing at the same load etc so the combinations are virtually endless. It will also support bigger airflow meters, different and custom meters, larger fuel pumps etc.
There are dozens of workshops that can tune the PowerFC you best reference would be a search in your local chapter (or car club).
For a PowerFC tune you are looking at a price of around $300-$500 varying on mods you have and car etc.
A list of known workshops who can tune PowerFC's;
Workshop Address Contact Notes
Racepace 9/6 Holloway Drive, Bayswater, VIC, (03) 9762 9421 Ben Track car specialists (incl. datalogit)
RE Customs 16 Yiannis Court, Springvale, VIC, (03) 9548 3414 Ray Premium tuner with Datalogit
Dr Drift Unit 4/9 Alick Rd, Brooklyn, VIC, 0425 818 755 Sam Premium tuning and remapper of std ECU's
CREATD Motorsports 11a Merola Way, Campbellfield, VIC Rob These guys have done GTR PFC on RB20
Croydon Racing Developments 9 Blaxland st, Silverwater, NSW 2128, (02) 96484264 Jim Premium tuner (incl datalogit). Built GTR700
Unique Autosports Unit 1/20 Tucks Rd, Seven Hills, 2147 John Premium tuning (custom RB26 PFC on VG30DETT)
If you would like your workshop listed here please email me and provide some information about your workshop so I can list you.
If you can install the PowerFC yourself you will save yourself some easy $ in the initial setup. Djetro PowerFC tunes will typically cost more so keep this in mind.
Australia Area Rep
Part 7
You sure can if you know. You can also look up some DIY threads using a lambda sensor and the trial and error procedure. Be warned you are playing with an electronic controlling mechanism of your engine and any incorrect setting could cause bad things. See the below parts on the Map Tracer for some info on Self Tuning. You can self tune the ignition timing yourself with trial and test method but you should not do this for fuel injection as you can lean it out too far and burn the exhaust valves which is permenant engine damage. Self ignition timing tuning can be done quite easily and will certainly aid in more fuel economy. It's not recommend for more power as this should done on a dyno so you can ramp up the load and max out to 200km/h without breaking any road laws / putting yourself at risk.
Map Tracer can used to work out what map the powerfc is currently using. Each map contains settings that powerfc should apply to the engine. A map is a 20x20 grid each position has a value. There are maps for fuel injection and ignition timing.
The map has 20 load points and 20 rpm points. Each rpm point is 400 rpm. This grid looks like:
A map for the ignition timing values looks like this (rb25det map)
A completed map trace in 2nd gear going from idle to redline looks like this. Please note this is done with full throttle, aka the pedal is to the floor:
Load is based on how much airflow the airflow meter is measuring. Going up a hill in 3rd gear at 50km/h may be represented as load value 13 if the airflow meter is seeing 4.1volts of "air" and an rpm point of 11 if you were at say 4400rpm. The load value (vertical left side) 13 out of 20 represents the amount of engine load being placed on it, which is taken from the airflow meter measurements. The ECU also knows how hard you've pushed the pedal based on the "THRO" sensor. So the powerfc uses these "values" that it's given in real time to work out what cell values to use for ignition timing and fuel injection. This forms the basis for tuning the engine as you can adjust any load point you like how you see fit. It's a little clear when you see the below diagram: If you were noticing an issue when under a certain load or rpm you could run a map tracer see what map cell is being read and then adjust the corresponding map value under ignition or fuel. To have the map tracer save the map its accessed on the map tracer screen press next when in map tracer and as it goes through the maps it will leave them on the screen. Just like if turned on mouse trails in windows, you see the previous trail it has left. This makes it easier to debug what the ECU is doing and what values need to be adjusted to alter how the car runs based on the map values being read in at real time.
Below is a map trace of light and medium throttle. This was done from my car based on a 15 minute drive around my local streets on what I would consider normal throttle. The majority of the time you aren't on full wide open throttle. Most tunes are done based on the car being on a dyno with the throttle wide open to check for safe A/F and tune for max power. This is fine however you will lack fuel economy as the a/f's for low and medium throttle are no where near the full open throttle a'f/s.
As you can see from this most of my time or "operation" is spent on the top left of the Map. Now remembering that load is up and down and rpm is left and right. So based off this trace we can see I'm not hitting much load, the most is about point 10 and rpm the most I'm hitting is point 8. So the max for that trace is load point 10 which is about 2/3 of the airflow meter max on the r33 gtst (The stock powerfc and afm can only show upto 15 points for 'load' reference). The rpm is 8 * 400 = 3200rpm. So I didn't go over 3200rpm and didn't give it lots of throttle but enough to access the lower end region. So going from this my fuel economy is fairly good but I am sure I can get better so we need to drill down to the fuel cell values for those highlighted maps as I am sure they weren't tuned on the dyno as this wasn't a priority for the initial tune. More to come on this topic as I further look into my tune and try and get some better fuel economy. Consider how much time you spend on full throttle vs low or half throttle and you'll realise where your fuel economy has gone. Out the window as the majority of the fuel cells you are reading are highlighted above and they are default apexi map values so they need to be tweaked.
If you goto ETC and then choose SENSOR CHECK/SW you will see a list of sensors and corresponding values. These report values that the current sensors are returning. This can be useful for checking faulty sensors and to check if a certain sensor is working expectedly. Below is a translated list of the ECR33 PowerFC
What are the basic mods I should have when I get my PowerFC?
You can fit the PowerFC whenever you like however a basic list of mods is a great start as you’ll get the most gain out of it from the standard computer
• Full Exhaust 3" from turbo back
• Boost Controller (Bleed Valve or Electronic Boost Controller - Or you can use the PowerFC boost controller kit)
• Air filter upgrade / Pod filter or CAI setup kit
• Upgraded Intercooler
_
Australia Area Rep
Part 8
Why does my engine light flash when I drive with the PowerFC?
The PowerFC uses the factory engine warning light to alert the user of "upper limit" or ceiling values in the engine systems. Things such as airflow meter max value, injector max duty, excessive knock will cause the engine warning to flash. Usually the engine flash is in a sequence of 3 flashes each 0.5 seconds apart. Should you experience this you should review the hand controller max values (press down when in monitor mode and displaying values to see the max values for each) and consult your tuner immediately. Excessively high knock can cause engine damage. Running on max injector duty can also be fatal so speak to your tuner. Aggressive tunes that are tuned around winter temps/airflow and being run hard in summer may cause these symptoms if the tune is very aggressive and on border line of maxing out the stock components. This is only hearsay but I have seen this from at least one or two members.
See Basic Hand Controller functions and use for information on how to isolate which warning is triggering the engine flash light
My idle is really crappy and it hunts around a lot when on idle. What can I do?
The first step when installing the PowerFC is to let it idle for upto 30 minutes on your car so it adjusts to your engine setup. This includes turning on the Aircon, Demister and Heater throughout the idle stages so the ECU has time to learn the engine setup and idle levels. This can be done by doing an "initialize" on the PowerFC. This will reset all settings back to default (including your tune) and set the PowerFC back to learn mode (for idle only). You should not do this if you have a tune as there is no way to save the tune before it is erased. If you have datalogit or the FC Pro cable/software you can copy the maps. Preform the initialize and then reupload the maps. A few people have seen really screwey idle from the Hand Controller itself being plugged in. The workaround is to unplug the Hand Controller and it idle's normally. This is a very strange problem and certinaly not common. Initial suggestions would lead to an electrical problem somewhere? If you still stuck with a unstable idle, try the factory ECU and does the idle bug go away? If it is still present it could indicate a mechanical issue with the factory idle control (usually the AAC valve). You can reset the PowerFC to factory defaults to "re-learn" the idle control from scratch and this seems to fix most idle related issues, such as hunting at idle and also high RPM surge when coming off a gearchange or throttle acceleration.
Last but not least if you still have screwy idle speak to an auto elec or mechanic. There could be something else wrong that requires further attention.
I am seeing on my Map Tracer that I am reaching load point 19-20 on full throttle. I am maxing out the PowerFC! What can I do?
Load or what is considered "load axis" on the powerfc maps is based on values fed from the airflow meter. If the airflow measure "lots" or air the powerfc moves down the axis on the left and reads the corresponding values. What happens when your AFM is showing the ceiling or "highest" values the powerfc has calibration for then you are stuck with a "flatline" load map which would look something like:
From here you can see it drops the max load points fairly quickly. This would most likely result in being unable to accurately tune from 4000rpm onwards as it just keeps reading the same load values each time (aka end of the map). This issue has only been found to occur with the AP Engineering RB20 PowerFC and using a "high load" setup such as an RB30 bottom end conversion. The issue is correctable by "extending" or "stretching" out the airflow meter reference points. This corrects it by when the airflow meter measures 3.2volts the powerfc matches that to load point 11 as an example. By default the AP Engineer PowerFC looks to reference the max load points a little early with an ugprade intake system and maxes out a little to early. This is not to be confused with the actual airflow meter maxing out at 5 volts. The correction in this case is to obtain the RB25 airflow map refence points and use them instead of the RB20 ones. This then "extends" the airflow meter range and allows it to run around the load point 15 mark on full throttle instead of the bottom of the map. This should allow for more accurate tuning as there is room for "increased" load because there are 5 or 6 "points" to advance in load before its at max again. This cannot be done with the Hand Controller as it requires the FC Pro software, Datalogit or Fc Tune to access the airflow ramp tables.
What do I need to do when changing my Airflow Meter?
When you choose another airflow meter to allow a large opening diameter or a higher resolution meter you need to select the unit from the [SETTING], [Airflow] menu and select it from the list. You should do this before you start your engine to prevent really unsafe mixtures and also to prevent stalling/bad idle. Once you have highlighted the correct model you have fitted to the car you can simply press [PREV] on the hand controller and return to normal [MONITOR] and start the car. It should idle OK (well hopefully) however this does not mean it is safe and ready to go. Selecting the correct airflow model simply loads the voltage ramp table into the PowerFC. This tells the PowerFC at what airflow levels the meter is reporing in its voltage range. You should have your AFR's checked with your tuner and a wideband after an airflow meter change to ensure its not too lean or too rich. If you need to drive a fair distance to your tuner or would like to run around for a few days on the new airflow meter without it being retuned/checked then theres a simple procedure you can follow
1. Let engine warm up and idle
2. Give the engine a bit of a rev in neutral and check to see if smoke comes out the exhaust.
3a. If you see *some* black smoke
-> Then its running rich (preferred) and it should be OK to drive around on light/low load, although your fuel economy will probably be terrible.
3b. If you see *lots* of black smoke
-> Then its running very very rich and you'll need to lean it out a bit. You can do this by going into [SETTING], [IGN/INJ] and then on the right hand side you will see INJ correction. You can then slowly change the ADJ value to a negative value in small increments. After a few adjustments give the engine a rev and there should not be as much black smoke. Repeat until there is a little bit but its not *lots* of black smoke.
3c. If you don't see any black smoke
-> Then its running lean or possibly too lean. Do the same procedure (as above) but add more fuel by adding or upping the ADJ value and after a few increments try a free rev. If you get some black smoke then you are starting to richen it up.
4. You should remember this value or write down the correction number used because if you turn the car's power off you must come back to here each time to put the value back in. This is because its only a temporary test mode and it should not be used all the time. You could also give this value to your tuner to give him an idea of how rich its running.
Source: Apexi Documentation
80m RB25 airflow meter can measure up to approx. 300ps (221kW)
80mm VG30 airflow meter can measure up to approx. 500ps (368kW)
90mm VH41 airflow meter can measure up to approx. 400ps (294kW)
*Output is calculated off of measurable air volume
Airflow Meter Adjustment Range
Using 100% as a base, the airflow can be adjusted from +50% (-50%) - 200%
A "complete tune" is not always a complete tune. It is most likely just a high power run, that is run the car on the dyno and suck out the most power you can and make sure it doesn't knock. Usually advance the timing, lean it out and make sure its a safe tune. This is done on full throttle usually in fourth gear (as stock diff ratio is 4:11) which is the closest to 1:1. Now think to your driving habits, how often are you on full throttle for the entire duration of your tank of petrol? 5% of the time seems reasonable but your entire tune is based on full throttle and max load, certainly not your ideal tune as far as economy. You should read up on how to use the Map Tracer here before continuing any further as you need to use this as part of the tuning process.
Speak to the tuner if you still have terrible economy. Ask to have the light cruise AFR's check on the dyno with a wideband sensor or even better as them to come for a drive with you wide a wideband sensor up the exhaust. Show the tuner your typical driving habits and make sure the AFR's are nice and lean on light cruise. My car is setup to be around 16 AFR's on light cruise which is safe & reasonable providing it is done correctly. Below is a simple checklist for poor fuel economy;
• Check the tune (light cruise AFRs etc)
• Make sure closed loop 02 feedback is on (ETC, FUNCTION SELECT, 02 FEEDBACK)
• Make sure you have a working 02 sensor (ETC, SENSOR SW CHECK, 02-1 (for gtst) should howver between 0 and 1v)
• Don't constantly load the car up to get it on boost over and over
• Keep a steady throttle (02 feedback doesn't work if you keep moving the accel pedal, keep it constant in light cruise)
Things you will need:
1 x Friend
1 x PowerFC Hand Controller
1 x Road
Australia Area Rep
Part 9
This should be done on quiet road with someone else driving your car. This should not be done by yourself, in peak hour, in lots of traffic or anywhere that seems obviously dangerous. Your own private road is probably the most suitable, and we all have these of course. Ok drive around normal load, cruise around 2200rpm ish. Watch the knock value under Monitor (1 Channel). It shouldn't knock excessivly, be sure to press UP so you get a "digital" value as well as the barchart on the hand controller. Knock is a signal picked up by a microphone inside the engine itself. It is not 100% accurate and it can pick up other things that are not "engine knock" but merely things that sound the same. Knock over 60 is bad and will flash the engine warning light, by default. Whilst on low load, light cruise goto Map Tracer and see what values are being read. It should be somewhere around say rpm point 7 (2200rpm) and load point 3 or 4. Just watch it vary around as your driver varies the load (varying accelerator pedal pressure). This is because as soon as the driver varies the throttle the engine loads up and takes in more air. The airflow meter see's this and increases its measured "voltage", which in turn adjusts what cell the PowerFC is using. Ok now goto Setting, IGN/IJN and on the left side you will see IGN Corr. By default it will be 0. Increase this value to +2 and then go back to Monitor, 1 Channel KNOCK and see if the knock goes up a little bit. A little increase in KNOCK is OK and acceptable, values jumping all over the place or constantly hitting 40/50 odd all the time is bad. You can clear the max "digital" knock value by pressing right when it is displayed along with the barchart. If the knock appears to be minimal then get your drive to vary the throttle a little. Try slowing applying more pressure to the accelerator pedeal in 5th gear at say 50km/h. This should throw the map trace down the left axis as the load increases. See if the knock goes up and down much as it's. Don't worry about full load, flooring it as we aren't interested in that. In fact this is not recommended as running advanced timing under heavy load can make stuff go bang. Try going into lower gears such as second and doing very slow takesoffs and very small amounts of load. Keep checking the knock values and make sure it is OK.
At this point you shifted the entire ingition timiing map up 2 degress everywhere. The car should be a little snappier and sharper under accerelation (This is good). As long as there is very little knock or hardly you should proceed to save this adjustment and monitor your fuel economy. It is recommended to do minor adjusments one step at a time to see the effects and also to prevent a big change instantly. +2deg timing increase should give a good increase in fuel economy. See if you can set IGN CORR to +4 and watch how much knock you get, if its minimal then its time to permenantly set the new tune. Again make sure its safe and not knocking before you do this. If you do this incorrectly you may have to either revert every value back or reset to defaults and loose your tune (You've been warned). Set the IGN CORR back to 0 deg and then let your driver have a rest or turn the car off but keep ACC on so you can keep using the hand controller. Have a rest and a drink as your eyes and head will hurt if you suffer motion sickness as watching map trace and knock while someone drives around really sucks. Ok now we wish to move the "light/medium" cells up 4degress. We don't want to move the whole map up as we've already had a max power tune which is fine we just want more economy. See below picture of what I feel are the light load / medium load cells which are used the majority of the time. These are the cells we want to "tune", aka thrown in our +2 deg correction permenantly.
For each of those cells highlighted, or even ones you wish (only recommended to do the first 8x8 as an abosolute maximum at this stage) do the following procedure.
1. Setting
2. IGN Map
3. Nagivate to cell you wish to alter, you can see the rpm points across the top, and load points down the left.
4. Press NEXT to enter the adjust cell screen which will show what RPM point and LD (load) point you are editing
5. Press NEXT to edit the value and then you can press UP to increas the value, in this case do it 2 times. The value will go from say 20 to 22.
6. Press NEXT to save the value change
As you can see by the above procedure it takes a bit of time to edit all the cells, the quick method is start at 1,1 and then press NEXT,NEXT,UP,UP,NEXT,RIGHT and repeat until you reach RPM point 8 or 9 and repeat for each load point upto around 8 or 9.
The optional boost controller kit for the Power FC consists of the pressor sensor, pressure sensor harness and solenoid. The solenoid should be plumbed between your manifold and the wastegate actuator (internal wastegate setup). For external wastegate setup it should be plumbed between the manifold and your external wastegate pressure line. The pressure sensor should be plumbed in parrallel with the factory MAP sensor which is used by your standar boost guage.
The solenoid has two labels on it, you should match them accordingly
COM line should goto wastegate actuator
NO line should goto intercooler piping
It can be T'eed into the plumbing with its included T piece fitting.
Boost Controller Kit Type #1
3 wire plug, Solenoid runs to stock boost control loom on stock ECU wiring loom.
3 wires in Apexi loom are for Map sensor - Signal, Ground and Power
Boost Controller Kit Type #2
5 wire plug, Solenoid runs to map sensor harness which runs to Boost Controller port on PowerFC
3 wires are for Map sensor - Signal, Ground and Power. 2 Wires are for Solenoid Power and Ground
Skyline RB25DET PowerFC and GTR RB26 Uses Type #1
The pressure sensor has the main wiring harness directly attached to itself, one end plugs into the 5 pin port on the PowerFC. The solenoid piggybacks off the Pressure Sensor wiring harness which leads to the PowerFC connector port. The wiring is shown below.
MAP Sensor
Red = Positive
Black = Negative (earth)
Green = Signal
Solenoid
Pink = Positive
Black = Negative
When the solenoid wiring meets with the Map Sensor harness the colours for the Soneoid change as follows;
Pink = Red
Black = Brown
Boost Control Kit - Parts Inventory
Boost Control Kit - Complete Kit
Boost Control Kit - MAP Sensor
Boost Control Kit - Solenoid
Apexi PowerFC - Plug Layout
Australia Area Rep
Discussion Starter #11
Part 10
How do I configure the Optional Boost Controller Kit?
Once the harness and sensors have been connected you need to turn the Boost Controller Kit on under ETC, FUNCTION SELECT. You need to set the Boost Kit option to ON. The OFF Symbol looks like a plus sign in Japanese so be sure its opposite to this. All that is left is to the set the disired boost pressure, SETTING and then BOOST. On this screen you will be presented with 4 options.
Each option is a preset boost pressure and duty item, the currently selected one is the active "boost profile".
The first value is Boost Profile Number.
The second value is the maxmium amount of boost you wish to run.
The third value is duty cycle
The fourth value is unused (always 255).
Boost Pressure
1. 1.00 kg/cm2 40 255
2. 1.10 kg/cm2 46 255
3. 1.20 kg/cm2 52 255
4. 1.30 kg/cm2 60 255
• Choose boost profile #1
• Set target boost pressure
• Do a test 3rd gear drive and see what boost it reaches
• Adjust duty cycle as needed
• Lower number if boost is too high over target boost or if safety cut is reached.
• Increase number if boost is too low or it doesn't reach desired level.
If the map sensors detects that boost pressure is 0.25kg/cm2 over the set boost pressure then it will do a safety cut to protect itself. If you find the car is unable to make the pressure you desire, increase the duty cycle value. If you find it makes it to easily or it's having trouble maintaing a stable pressure or keeps hitting the cut limit then turn the duty value down. You can also set the other 3 boost profiles here if you wish so that you can select these later on allowing you to quickly change preset boost on the fly. The current selected profile (option 1,2,3 or 4) is active when you it's highlighted and you press PREV to navigate to the other menu's.
Basic Duty Setting
Our boost control uses duty-cycle of the solenoid valve to control boost pressure. The setting of this duty-cycle decides the basis of the control to match actual boost with desired boost level.
The numerical value should be increased when the boost level does not reach the above-mentioned setting. The numerical value is decreased when the boost level surpasses the above-mentioned setting (desired boost level).
A rule of thumb is that it changes by the boost value by 0.1 (about 9.8kPa) when duty cycle changes approximately 6%.
For example, when current duty is 56% and boost setting is 1.1[] (approx. 107.9[kPa]) but the boost raises only up to 1.0[] (approx.98.1[kPa]) , in order to raise 0.1[] (approx. 9.8[kPa]), you have to change the duty from "56%" to "62%".
Some mechanical conditions may prohibit boost from reaching the target boost.
Please set it to the correct duty value that corresponds to the boost setting value.
Please note that it causes the overshoot or hunting of boost pressure and self learning control if the boost selection and duty-cycle does not match.
How do I hook up the D-Jetro Map Sensor Harness Kit?
There are various installation methods for the Djetro Map Sensor depending on the Car Model.
This will depend on your car - it's recommended to view the documentation for your specific Djetro model.
The manual will be in Japanese but the wiring should be in clear english with pinouts etc.
• Evo Lancer CT9A do not have to do anything as the car runs a factory Map Sensor
• Skyline RB26 customers must splice twin Map sensor into the Airflow meter signal wires on the std ECU loom
• Nissan S15 customers must also manually splice a single Map Sensor into the harness (via AFM signal wire)
Below are instructions on how Skyline RB26 customers should connect up the Djetro kit.
It appears that D-jetro customers must splice the twin map sensors into the Boost Control Kit harness (or at least use the same port) to extract positive and negative power.
The signal for each MAP sensor is then connected to each of the AFM input signals on the main ECU loom.
So Map sensor #1 which is located near Cylinder #3 on the intake plenum runs to AFM input #1 on the ECU loom.
and Map sensor #2 which is located near Cylnder #4 on the intake plenum runs to AFM input #2 on the ECU loom.
For a more in depth diagram and guide please view the correct manual for your car's Djetro version as it will have correct Map Sensor wiring.
________________________________________
Basic Hand Controller functions and use - Monitoring
Basic hand controller use is very simple and you can check and ensure your engine and system is running happily. Monitoring Values
Highlight "Monitor" on the menu and press NEXT and then select how much values you wish to view and then press NEXT.
Australia Area Rep
Discussion Starter #12
You can now select which items you wish to monitor from the menu below
InjDuty - Injector Duty / How busy the injectors are
IgnTmng - Ignition Timing - Camshaft timing
AirFlow - Airflow meter voltage
PimVolt - Map Sensor voltage
Eng Rev - Engine revs
Speed - Road speed
Boost - Boost Pressure (requires optional boost kit fitted)
Knock - Knock sensor reading
WtrTemp - Water temperature or engine temperature
AirTemp - Air inlet temperature (sensor is not fitted on ECR33 skyline, DO NOT attempt to make this work)
BatVolt - Battery voltage
(Standard ECR33 Skyline menu options shown)
If you want to monitor your injectors and airflow meter select both of them after you choose 2 channel and then press next. You will then see them in their digital output mode on the hand controller. You can press UP to show their maximum values at any one time. You can press right to clear their maximum values. Any max values you see are cleared when you turn the cars power off.
The knock sensor when you view it by itself (1 channel) will give a bar graph like display showing knock. The Knock value is not number of knocks per second or knocks per engine turn, its just a number. The factory knock sensor is a microphone in the engine that listens for a certain frequency. When it detects this frequency it registers this as a knock, the higher the value the worse it most likely is.
Airtemp will always display --- on the ECR33 skyline as there is no air temperature sensor on the RB25. GTR / RB20 uses will have a value displayed which should show the air intake temperature. On the RB26 this sensor is located next to the throttle body inlet.
when viewing values via MONITOR you can also press NEXT and it will alternate between digital display and graph mode. When in graph mode you can use the "replay" function by pressing up and then PREV / NEXT
Basic Hand Controller functions and use - Checking Functions
Checking Functions
Highlight "ETC" and then choose "FUNCTION SELECT".
BOOST CNTL KIT - Enable/Disable optional boost controller kit
AIRFLOW WARN - Enable/Disable airflow warning
INJECTOR WARN - Enable/Disable injector warning
KNOCK WARNING - Enable/Disable Knock warning
02 F/B CONTROL - Enable/Disable 02 feedback
If the boost control kit is turned ON and you are not using it (not plugged in) the car will not start.
If the AIRFLOW WARN is set to ON the engine light will flash when the airflow value gets near its ceiling limit of 5 volts.
If the INJECTOR WARN is set to ON the engine light will flash when the injector duty values gets to 98%
If the KNOCK wARNING is set to ON the engine light will flash when the knock level exceeds 60
If the 02 F/B is set to ON the engine will utilise the factory oxygen sensors to save fuel
If you see your engine light flash whilst driving then goto MONITOR, 4 channel and then select
AIRFLOW
INJDUTY
KNOCK
IGNTMNG
Then repeat the same process and then press UP on the hand controller once you see the engine flash to check the max levels of each sensor you are monitoring. You can then work out which is causing the engine light to flash. On a stock ECR33 with the basic mods fitted youll find that you are maxing out all the factory sensors so in that case I turned my AIRFLOW and INJECTOR warnings to OFF and leave the knock sensor warning to ON. So if you see the engine light flash its a kNOCK warning and should be taken as a true "warning". You should speak to your tuner if you see high knock levels and the engine light flashing. A knock level of 60 is considered quite high.
If you have 0/2 Feedback turned off the PowerFC will not enter its closed loop feedback mode and will waste fuel and be very un-economical. Expect bad fuel economy
Basic Hand Controller functions and use - Checking Sensors
Checking Sensors
Highlight "ETC" and then choose "SENSOR/SW CHECK"
BOST will show voltage if you are using the optional powerfc boost control kit
Airtemp sensor on unsupported car?
Some PowerFC's have support for the AirTemp sensor under MONITOR but the car itself does not utilize a factory air temp inlet sensor. I attempted to hook up an airtemp sensor on my ECR33 PowerFC and fried the powerfc and damaged a sensor on my car. The concept was to look at which pin on the BNR33 PowerFC the air temp sensor was connected on and then try and replicate this on the ECR33 PowerFC. I tried this and it did not work, I tried an adjacent wire and it fried the PowerFC. It has since been fixed and all is working but I do not recommend you try to get this working. It may work out costly like it could have been in my case.
Can you reflash the PowerFC with new code and/or different versions of the Apexi code?
The newer model Apexi PowerFC's have a different model NEC processor and also feature an onboard connector, possibly for reflashing internally by Apexi staff and / or authorised dealers etc.
If you open up your PowerFC unit and you see a processor which has;
NEC Processor: 78P3 CPU
Not reflashable
NEC Processor: 78F4 CPU
Reflashable
For more information on this check out the thread on the RX7 forum by FastHatch. He has done some extensive research on this and found that they are reflashable and can be altered providing you know how. Some good news possibly :)
Are there any cool custom hacks, hand controller holders, DIY rewiring you can do?
There are a few custom mods you can do some clever, some not so clever. The pictures contained below are mostly taken from the Rx7 forum and other forums found in google. Some show some clever hand controller holders you can get, generic mobile phone holders should work fine.
What is Datalogit?
Datalogit is a 3rd party system for the Apexi PowerFC. The system/kit includes of a dongle box and software. The dongle box plugs into the Hand Controller port on the PowerFC and the software runs on a laptop connected to the dongle box via a serial cable. The dongle box has a Hand Controller port so you can keep the normal Hand Controller connected whilst using Datalogit. The Datalogit dongle box translates the PowerFC signals from the Hand Controller to signals to the COM port on the dongle box which are used by the software running on the laptop.
Australia Area Rep
Discussion Starter #13
Part 12
What does Datalogit do, is there a feature list?
The software has many features as to does the Dongle box. The dongle box has the following "external" features for use with the software. The Dongle box supporst Anti Lag, Boost Scramble and Wideband 02 Input. The software has the following items which are not accessible via the Hand Controller:
• AFM voltage table
You can choose to log values from the sensor list that you see in "SENSOR/SW CHECK" and also the ones in MONITOR so you can log some of the engine items that you can't normally view in MONITOR but are visible in "SENSOR/SW CHECK".
Once of the most useful features I have found is the "Advanced Logging" system which logs a selected "item" and plots it's min/max/avg values on a map tracer field. So you can log KNOCK against a map tracer view and it will plot min/max/avg KNOCK for each map tracer cell in real time. This allows you to quickly identify which cells are knocking more than others, so you can adjust the timing for that particular cell. Below is an "Advanced Knock" watch that was done for a quick run around the block in my ECR33 RB25DET Skyline. You can quickly see which cells are knocking more than others, so I would easily know which cells I could afford more timing and other cells where I would need to take out some timing due to excessive knock as an example. This method of loggin and map trace is aviable for any of the loggable items.
If you wish to see a log run or an example of the data logged then please click here to download an Excel Spreadsheet of a run my car did just around the local block.
What does the box look like and what's inside it?
The dongle box has a very simple circuit diagram to translate the communication between the PowerFC and the software. The PowerFC protocol has checksumming and error correction in the protocol so I assume this is what the PIC processor is used for. The Dongle box also analog and switchable inputs which can be used for 3rd party tools (as listed above). Below are some pics of the Dongle box. Note: I do not proomote disassembling or reverse engineering the box but merely took some pics for "curiosity" sake.
Do you really need to have it or is the Hand Controller OK?
Datalogit is not required for normal use and even tuning. Things are easier with datalogit and you can much easier (as addressed above) when correcting knocking and other tune based issues as you can quickly find what cell has the min/max/avg of any value. It also allows you to save your tune to a .dat file in case you reset your unit or it gets damaged somehow. I found it very handy to plug datalogit into a laptop and use the laptops video out to my built in TV screen to preform Advanced Knock log whilst driving around, very helpful but certainly not required. The Datalogit kit is required when you move to a Q45 airflow meter or other unsupport airflow meters as you need to alter the airflow voltage ramp table. Selecting VH41 from the menu does allow it to run but it usually needs to be fine tweaked via the voltage ramp table.
Where did you get it from and can I buy one? What is support like?
Datalogit can be purchased from http://www.fc-datalogit.co.nz (Brand new its about $500 AU) or from a 2nd hand user on the forums or even a group buy. There is a small delay from the time of purchase, to receiving the Datalogit box and software. Support is formed as an open community user group as opposed to a phone number or online web page. Latest versions of the software are also available in the user groups for download.
Boost display without the Boost Control Kit?
By default as the PowerFC will not show boost pressure as it has no method of reading it in via the stock ECU loom. If you purchase a suitable map sensor and connect it to the PowerFC boost control kit port then the hand controller will display boost pressure. The boost control kit uses a Denso map sensor which is part #DPS 310 2000a - Denso 949940 6270 5V and the wiring loom cable/plug can be brought from Apexi which is around $40 AU. The cable is listed as the 3pin boost control harness. Nengun has this listed under Electronics -> Apexi -> D Jetro Option Parts
Alternatively below is the pin out diagram for the Boost Control Kit port. This is for the 3 pin version only. I am unsure of the pinouts for the 5 pin version.
1 = Voltage+
2 = Signal
3 = Ground
I have done this on my car and it works correclty. I used the boost control kit harness ($30 new) and the Boost Control kit Map sensor. Connect them up using the supplied plugs & loom and plug it into the PowerFC Boost Control kit port. You don't need to enable the Boost Control Kit (under ETC, FUNCTION SELECT) for it to display boost and for BOST to work in ETC, SENSOR SW/CHECK
Is the PowerFC Pro Discontinued?
Apexi have discontinued the PowerFC Pro model which was the special version of the PowerFC that had IGN cut instead of Fuel cut and also had a REV LAUNCH function holding the rpm at a set value at 0km/h. For some cars the PowerFC Pro model exists (RB26, RB20, WRX) but for most models it has been discontinued. Apexi have not released any information as to why the model's have been discontinued or if there will be a new model coming out. Those customers who must have the Pro models should look for a 2nd hand unit instead.
For alternate solutions for "Pro" style functionality check out Apexi PowerFC Djetro PRO - Does it exist???
Australia Area Rep
Discussion Starter #14
guys ill upload the rest later on tonight, got to head out for a sec
glad your typing skills are way better than mine sau lol
Australia Area Rep
Discussion Starter #16
Part 13
Help! My car doesn't idle once I've installed the PowerFC
Your car should idle straight off the bat when it is installed on your car and you start it for the first time. Make sure you complete the idle procedure correctly and let it idle for 10 minutes in each stage. If you rush the idle self learn procedure you may end up with a car that doesn't idle. If this happens simply reset it. You should also check to make sure your AIRFLOW meter is selected correctly under SETTING, AIRFLOW (you can do this before you start the car).
Have a read of My idle is really crappy and it hunts around a lot when on idle. What can I do? for some more help on unstable idle etc.
Self Tuning - Fuel Economy
1 x Friend
1 x Wideband Sensor
1 x Wideband AF Guage or Digital Guage
1 x Road
1 x Workshop with Datalogit or a Pen + Paper (Get your tune saved before you fiddle - Either have a datalogit owner save the tune, or you write down each cell value into an excel spreadsheet for the INJ map as you will be adjusting those values and if yo do it wrong, you should at least have the option to go back to how it was)
!!!!! Before you Begin !!!!!
Turn off 02 Feedback under ETC, FUNCTION SELECT
14.7 AFR means an Air/Fuel Ratio of 14.7 parts to 1. 14.7 is 1.0 Lambda which is ideal AFR for fuel economy and power. A richer AFR such as 13.0 will use *more* fuel as it is richer, ie there is less air to the mixture and it will make less power, however it will have less exhaust heat. The leaner the AFR the more exhaust heat there is and the more power you will make. It is NOT safe to have say an AFR of 14.7 at max/full load as there will be too much heat. Generally full throttle or max load AFR's are around 12.0 as this keeps the exhaust heat down considerably and is often referred to as a "Safe" AFR as its richen'ed up to make sure its safe. Freeway cruising at 100km/h you should have an ideal AFR of 14.7 as this is safe enough to keep the heat down but good enough for economy. An AFR of 15.0 at 100km/h is not safe as you will generate too much heat
Lean - More Power, More Heat, Less Fuel Usage
Rich - Less Power, Less Heat, More Fuel Usage
Light Load - Leaner (use less fuel and make resonable power)
Full Load - Richer (use much more fuel to keep exhaust gas temperatures safe and make good power)
You may find a factory ECU when you go on the dyno and do a full load run that it may drop into AFR's of low 10's/11's. This is because the factory ECU is just dumping fuel to protect itself and make sure things are cool and hunky dory. The factory ECU's main priority is not to make max power at 5700rpm unlike a max power tuned ECU. A piggyback controller on the factory ECU that allows to ECU to see altered airflow meter signals make's the ECU run leaner in areas so you can make power usually.
This should be done on quiet road with someone else driving your car. This should not be done by yourself, in peak hour, in lots of traffic or anywhere that seems obviously dangerous. Your own private road is probably the most suitable, and we all have these of course. Ok drive around normal load, cruise around 2200rpm ish. Watch the wideband sensor and get a feel for what the values are and how quick it reacts to throttle and load changes. The sensor should react almost instantly to throttle changes and should be no more than 1 second off real time.
Ok now pick a cell area and get your driver to keep the throttle pedal the same so that you sit on the same Map Cell in Map Tracer. An easy one is say 60km/h which should dial in you at RPM cell 6 and load cell 3. Watch the Wideband AFR (lets pretend its 13.2 AFR). We now know that the AFR is 13.2 which is fairly rich and we can certaintly dial it out a bit leaner to get some better economy (14.7 is ideal).
Now goto Setting, INJ Map and navigate to the cell that map tracer was showing you, 6x3 is the area in this example. Lets pretend that the cell is 1.012 in the INJ map for that cell. Now we want to "lean" it out so we simply take some fuel out of the cell, so press NEXT and the press down say 5 times. This should now make the value around 1.000 or 0.995. Once you are done press NEXT and the value will be saved. Now check the wideband sensor and the AFR should have dropped a little. Hopefully it has moved towards 13.6 ish by those simple adjustments.
If it hasn't moved check
1) 02 Feedback is OFF
2) The car is still using map cell 6x3, check Map tracer again, 6 should be REV point and 3 load point (or whichever cell / area you are editing)
Keep watching the wideband sensor output and take out a few more cells, keep repeating this until you reach your desired AFR for that cell. Once you are happy with the AFR dialed in for that cell get your driver to say drop 10km/h off the speed and this should move the REV cell down to say 5x3. Then make sure its the same in map tracer, check the AFR value off the wideband and goto INJ map and edit it's value until desired AFR is reached. You should repeat this step for all cells in the 7x7 area and this is the majority of your light load / cruise economy.
For each of those cells highlighted, or even ones you wish (only recommended to do the first 7x7 as an abosolute maximum at this stage) do the following procedure.
1. Setting
2. IGN Map
As you can see by the above procedure it takes a bit of time to edit all the cells, the quick method is start at 1,1 and then press NEXT,NEXT,UP,UP,NEXT,RIGHT and repeat until you reach RPM point 6 or 7 and repeat for each load point upto around 7.
Hybrid Apexi PowerFC models and mix n match models, can it be done?
Whilst this type of work is possible and it can work there are some known gotchas and things that don't work so be sure to read it in full and understand everything before you go ahead and do it. Lastly there are some workshops that can do this for you, this is common for exmaple using the RB26 GTR PFC on the R33 GTST, there are workshops who can fit this and tune it for you. Some of the known gotchas are the 02 sensors, loss of VCT and AFM ramp tricks that are required to make it work.
It is in fact possible to interchange Apexi PowerFC models to suit other engines. That is to, rewire an existing model to work on another engine and loom. Below is a list of the combinations possible and how to achieve the goal of making it work. Please note this information is taken from the Forums are various peoples opinions and ideas, it is not %100 guaranteed nor have I tested each of these myself, so you've been warned.
Apexi RB25 PowerFC on RB20
To run the RB25 PowerFC you need to swap injector triggers for cylinders 4 and 6. This is wires 112 and 114 on the RB25 ECU pinouts diagram which can be found here. You also need to run larger than rb20 injectors. You should be able to swap to Rb26 440cc injectors without much fuss and this should work, providing you dial in the correct injector latency and correction (and use the resistor pack).
Apexi RB26 PowerFC on RB20
The traditional Ap Engineering RB20 model is in fact and RB26 model remapped to suit the RB20 loom and sensors. The main differences between the two is Airflow meter and 02 sensors. The RB26 having two, and the RB20 having one of each.
Australia Area Rep
Discussion Starter #17
Part 14
Two AFM:
If you are using two airflow meters you will need to run wiring for the second airflow meter manually as the RB20 loom only has support for one airflow meter.
One AFM:
If you are using one airflow meter you can simply parrallel up the airflow meter signal into the second input on the RB26 ecu. The ECU will average out both signals despite it coming from the same airflow meter to work out engine load (or airflow load).
02 Sensor:
The RB26 uses two 02 narrowband sensors to run in closed loop correctly. Simply parrallel up the oxygen sensor into the second 02 sensor input on the RB26 ECU.
Hybrid RB30DET
You can use any variant of the Apexi PowerFC on the RB30DET. It would be easier using one that suits the head you are using and loom. The likely recommendations for the RB30DET would be the RB20 or RB26 version. You don't need to worry about VCT with either of those choices.
Notes:
If you use the RB26 PowerFC on your hybrid or standard engine you have the best pick of the bunch. You have the following advantages;
Able to use two airflow meters when a single becomes a restriction Have access to the Apexi PowerFC Pro version Have access to the Apexi PowerFC Djetro version
Apexi PowerFC RB20 vs Apexi PowerFC RB25 wiring
Here are the main differences in the wiring loom for the RB20 vs RB25
Apexi PowerFC RB20 SENSOR SW CHECK
Apexi PowerFC RB25 SENSOR SW CHECK
Differences between RB20 and RB25 looms
Here is a version matrix for all the Skyline PowerFC's and their feature set
From here you can see the RB26 version is the pick of the bunch if you are going to run a different PowerFC for your engine/head combination. Choosing the RB26 version allows you to select
• Djetro or Ljetro
• Pro Version
• Single or Twin AFM (if single parrellel up the single AFM onto both AFM inputs)
As an experimental branch I am trying to wire up and sell 26 PFCs to suit Rb20 and Rb25. This will negate the lack of production by Apexi/NEC and give Rb20/Rb25 owners a chance to still buy and use the PowerFC. For more details on this please read http://www.skylinesaustralia.com/forums/index.php?showtopic=161511
When I turn my car off I loose any changes on the PowerFC! Help!!
Any changes made to settings on the Apexi PowerFC are written in memory and then commited to NVRAM when the car is powered off. When the PowerFC detects power loss to IGN it saves its state into NVRAM. This usually takes around 1 second. Once this is complete the unit is safe to be powered off (happens automatically). If your car has had an engine swap it is possible and likely that the standard ECCS wiring has been altered or is not the same as factory. This may mean that when the IGN is turned off the PowerFC doesn't have time to save its changes. This results in any changes made to be 'lost' when the power is off. Below is a diagram on how it should be wired in with the ECCS relay. The diagram is suited for the RB26 ECU so if you have a different version look up your corresponding ECU's diagram for the matching wires.
If the power to ECCS and COILS are taken from the Ignition the PowerFC will not have time to save it changes, as a result it will be stuck in a read-only mode. The fix is to wire it correctly into the matching ECCS and COILS wires as per the diagram.
How do I configure larger injectors?
Configuring larger injectors into the PowerFC is quiet simple and takes only a few moments. You need to know the following information before you can continue
• Current injector size
• Current injector latency
• New injector Size
• New injector Lag time
Injector Size and Latency (standard units)
Unit Size Latency
RB20 260cc/min 0.890msec
RB25 370cc/min 0.528msec
RB26 444cc/min 0.772msec
SR20 (Jap Spec Manual) 448cc/min 0.584msec
Nismo 480cc 480cc/min 1.100msec
Rx7 550cc 550cc/min 0.730msec
Aftermarket New Units 600cc/min 0.810msec
To work out new INJECTOR correction and latency;
Old SIZE / New Size = Correction
New Latency - Old Latency = Latency Correction
John plans to install 600cc injectors into his RB26 VL Turbo. The following figure's are used;
444 / 600 = 0.74 * 100 = 74.0%
0.81 - 0.77 = +0.04 msec
So he would enter 74% for correction and 0.04 as new latency
Once you have switched to larger injectors you should still check your AFR's with a wideband to ensure they are safe and acceptable.
For a list of common OEM injectors and their settings try here;
Injector Chart - Side Feed OEM
Injector Chart - Top Feed OEM
If changing 440[cc/min] to aftermarket 600[cc/min]
440 / 600 = 0.73
Enter the value "0.73" for each cylinder.
Bolt-on turbo spec. POWER FC applications assume that the injectors have been upgraded. This is why "1.000" is not entered as the starting data for the injector values.
Australia Area Rep
Discussion Starter #18
Part 15
Injector Lag Time Setting
The POWER FC includes factory vehicle injector data. If you switch to any other type of injector, be sure to perform the calculations below and input the correct values.
Changing the factory 440[cc/min] with 0.78[msec] injector lag time to an aftermarket 600[cc/min] injector with 0.85[msec] injector lag time is:
"Injectors to be used" - "Factory Injectors" = "Correction Value After Changing"
0.85[msec] - 0.78[msec] = 0.07[msec]
Enter "0.07" into the [msec] parameter for each cylinder.
*If the aftermarket injectors have a shorter lag time, add a "-" (minus) before the value.
On this screen you need to enter your new Correction% and Latency. Be sure to double check these numbers and consult your tuner if you are unsure.
If you enter the wrong values, this could be fatal to your engine so be careful.
Apexi SAFC vs Apexi PowerFC, whats the difference?
My cousin Peter just brought an Apexi SAFC for his R33 skyline and he had it tuned and made 204rwkw. It cost him $300 and $250 for a tune. Most people simply assume you can make power and expect 220rwkw.
They will both make very close to the same amount of power if both have been tuned correctly. But clearly the PowerFC winds hands down if it has been tuned correctly and has a bulk of its load points tuned. If you have the IGN and INJ tuned in the low load / light load areas the car will feel much better to drive, response will be better and fuel economy better than the SAFC + stock ecu. The main difference is the PowerFC will support more mods and if tuned correctly will feel like a new car to drive.
Both are only as good as the tuner.
Car 1 - rb25det with SAFC
Car 2 - rb25det with PowerFC
The truth is that car #2 isn't likely to make twice the power as the ecu costs twice as much. It all comes down to tuning and how the car drives, average power is the key here. The engine should feel nice on throttle response (IGN timing), come on boost nice (IGN timing) and cuirse will with good economy (INJ tuning). I would expect the power difference to be 5 to 10rwkw at the most in the midrange and top end.
Distinct Advantages:
Adjustable IDLE
Configurable knock warning
Configurable injector warning
Configurable airflow meter warning
Airflow meter change support
Injector change support
Complete ignition map control
Complete fuel injection map control
No speed cut
no excess airflow cut (aka boost cut)
The main problem with an SAFC and increase power levels is that its still a piggyback and when you tune more and more, it's still a comprimise. As you try and lean it out more, it (the stock ecu) advances the timing as a result, which results in more detonation. The end result is it has to be richer than is needed, to avoid detonation. With the PowerFC you can simply dial in whatever AFR's you like and IGN timing to suit, anywhere on the map. This would certainly give a good power advantage in the midrange and top end.
What are the percentages for my airflow voltages for?
The airflow meter percentage or "correction" per AFM voltage braket is simply that, a correction for each voltage range. This allows the tuner or operator to show more or less Airflow to the Load map, which in turns moves it final load bearing on the load map.
At 80% for the say 3.20v braket means that any airflow between 3.20v and 3.84v (standard GTST scaling) will only show 80% to the laod map. So if by default it was to land on load points 10 through to 13 then it would end up landing on load points 8 to 9 instead, 80% of the airflow load. You won't have less or more power as the same amount of airflow comes into the system, it just affects how it is represented on the load maps.
This allows the tuner to move the load bearing around on the map quickly and easily to effectively shift the map up and down. The benefit of doing this is you can quickly shift the load bearing around without adjusting 60 odd load points on the load map, for IGN and INJ settings for a given AFM voltage bracket. This is one of the more common methods for quick tuning of the PowerFC but certainly not the only one. This is more common with standard to mild setups, which can include Cams, Turbo's, AFM's etc. There does come a point and time where it is quicker to just leave the voltage correction all at 100% and move on the maps directly and begin altering the INJ and IGN values directly.
Is there a way or guesstimation to calculate AFR's based on the INJ values?
You can use the following calculation as a guesstimation for target AFR's
Target AFR = 14.7 / INJ value
This is by no means a true relationship to the AFR's that come out in the end. It is exactly that, a guesstimation or rule of thumb. You should always use a fast and wide lambda or 02 sensor to determine the true AFR's The most recent version of datalogit lets you view the INJ table in Lambda, INJ values and AFR ratio using this method.
Apexi LJetro Vs Apexi Djetro - Whats the deal??
For some time this debate has gone on with various opinions and ideas with no real concrete evidence/proof or logic to back it up.
There are two distinct differences between the LJetro and Djetro PowerFC (and presumbably other LJetro/Djetro ECU's) and we will discuss them as this is a hot topic.
Having since worked out the mathematics behind the Load axis calculations for both the Ljetro and Djetro versions of the PowerFC I can show you how they are both calculated.
First we should look at each base model and how it works;
• Apexi PowerFC Ljetro Version
• Uses standard airflow meter
• 20x20 Load Map
• Other addtional supported airflow meters (selectable on menu)
• Apexi PowerFC Djetro Version
• Uses optional supplied Apexi Map sensor
• 20x20 Load Map
• Other addtional supported map sensors (selectable on menu with correct voltage and offset)
Both units are scalable upto 1100bhp with supported modifications, sensors, injectors etc.
i suspect the ljetro version was created first, and then Apexi following demand added the Djetro version for some select cars as they found customers were migrating to other ECU's to map sensor support.
Ljetro Vs Djetro Load Axis:
Both have arbitary values for Load indiciation, Djetro has higher RPM as its from RB26 Djetro
Airflow Meter Ramp:
Voltage Ramp for Airflow meter load signal. Infinitely scalable, as we can rescale any given airflow meter.
The most commoin airflow meters are supported out of the box, Z32, Q45 and Apexi Power Intake.
Seemingly all the Apexi Power Intake does it alter the ramp values, which should yield slightly higher airflow load values, which should drop them on the map 1.3rows if that, ever so slightly.
Map Sensor Ramp:
Voltage Ramp for Map Sensor. Each sensor has a single Offset and nothing more. Fixed offset value
Optional Map Sensors include GM5bar map sensor and Denso unit's also. The Apexi one is in fact a Denso unit. The only map sensor supported out of the box is the optional Apexi one (denso rebadged).
Australia Area Rep
Discussion Starter #19
Part 16
GM 5 bar and other sensors need their scale and offset placed into the PowerFC to work.
Apexi Ljetro Load Calculation:
LOAD = CORRECTION * (16384 * Airflow lookup(MAFSV) / RPM)
Airflow is proportional to RPM so this is why we are divisible by RPM.
We obtain MAFSV from our running environment.
We lookup the Airflow value from the Airflow ramp table (viewable by datalogit) and use this value.
We lookup the CORRECTION value from the Airflow corretion table, for 4.48v and higher my correction is 84%
ACR MAPN MAPP Rpm Load MAFS1 V MAFS2 V Inj ms Inj +/- IGN Dwell Boost Duty WtrT AirT Knock
0 11 14 4694 10725 4.705 0 15.568 256 21 51 -760 95 75 175 7
0 10 14 4591 10918 4.73 0 15.88 256 21 51 -760 95 75 175 4
0 11 14 4725 10915 4.745 0 15.952 256 21 53 -760 95 75 175 1
0 11 14 4950 10956 4.835 0 16.08 256 21 54 -760 95 75 175 3
0 12 14 5175 11121 4.9 0 16.528 256 21 58 -760 95 75 175 7
0 12 14 5202 11153 4.93 0 16.632 256 21 58 -760 95 75 175 7
0 13 14 5561 10997 4.99 0 16.464 256 21 62 -760 95 75 175 3
LOAD = 0.84 * (16384 * 3598 / 4950)
The answer gives us 10003.57 and we can see for load point 14 we have an Load value of 9642.
The load value for point 15 is 11571 so we place our load axis on 14 with a value of 10003
As we can see here the load will always increase as the engine speed increases.
More and more air comes into the system and thus airflow load will always keep increasing until redline.
There have been doubts over this as many people see bog stockish R33 GTST's drop to load points 15 and shoot across.
This is due to the fact they are maxing our the airflow meter at 5.10 or very close to.
The reason it drops to load point 15 is because the majority of them have airflow % correction somewhere near 80% for 4.48v and higher.
Appexi Djetro Load Calculation:
LOAD = Map Sensor Offset * Map Sensor(PIMV)
We lookup the Map sensor offset and use this value (viewable by datalogit).
We obtain PIMV from our running environment
BatVolt MAPN MAPP Rpm PIM PIM V TPS V Inj ms Inj +/- IGN
14.3 2 8 1515 6565 1.996 0.501 2.111 152 14
14.3 2 8 1499 6414 1.95 0.501 2.007 152 14
14.3 2 9 1536 6782 2.062 0.501 2.176 152 14
14.3 2 9 1529 6696 2.036 0.501 2.184 152 14
LOAD = 3289 * 1.95
The answer gives us 6413 and we can see for load point 8 we have an Load value of 5938.
The load value for point 9 is 11571 so we place our load axis on 14 with a value of 6681.
As we can see once pressure is fixed or doesn't increase any more, the load value doesn't.
This will result in a horizontal shoot across method once target boost pressure is reached.
This is because the Djetro version uses air pressure and runs a guesstimation method to calculate airflow.
As the engine speed increases more and more air comes into the system, pressure remains the same and the load axis remains the same.
The Djetro has two additional features which are;
IGN vs TPS correction
INJ vs TPS correction
These are there presumably to assist in correction for the throttle position sensor.
These will have an affect on the output figures but don't appear to adjust the load bearing.
These are much like Airtemp correction or water temp correction, they affect values but don't adjust load bearing.
Ljetro
Pro's
• -> Out of the box, works great, plug and play nothing more to add/change
PR: This is suitable for the majority of customers
• -> Supports factory airflow meters and larger models
PR: This is suitable for the majority of customers and tuners (less fiddling the better)
Cons'
• -> Some tuners/owners believe the airflow meter is a restriction
PR: Turbocharged cars have a restriction after the compressor outlet, not before.
• -> Once you max out the airflow meter it can't show any more useful load to the ECU
PR: Once you max out a given airflow meter, move to a larger unit with higher resolution.
If you stay with an airflow meter maxing out (stockish GTST customers) then you basically have the same
load bearing as Djetro customers. Once you peak or reach max airflow (the most the AFM can show) then Load doesn't increase anymore.
This is dead obvious for stockish GTST customers who do a map trace.
Djetro
Pro's
• -> No air intake restriction
• -> No airflow meters in pipework
PR: This can be helpful for large twin applications. It may also help avoid chuffing or compressor shuffling.
With correct pipework and bends you should be able to run twin MAF's or even a big single MAF relocated in the after FMIC pipework
• -> Can't max out airflow meters
PR: This is a valid Pro. But once you max out any airflow meter simply change to a larger unit or more scalable unit.
Con's
• -> You loose load point resolution once you reach target boost (horizonatal shoot across, as pressure never changes)
PR: This would be my main caveat of moving to map sensor system, the lack of tuning points, as the map isnt a 20x20 useable map anymore.
When I turn my car on I get a clicking relay noise and the hand controller dies
This is related to an ECCS / Power source wiring problem. Either the PowerFC does not have the right voltage, a chip/circuit is damaged in the PowerFC or the unit is possibly faulty. When I fried my PFC due to a misconfigured wiring loom I had this problem. I opened up the PFC and found a burnt track. I resoldered the burnt track and all was well. I encounter loud clicking noises from the PFC, and garbled text and characters on the hand controller when the IGN had power. You can view a similar topic here When I turn my car off I loose any changes on the PowerFC! Help!!
My Skyline R32 GTR has a wierd misfire problem, what's wrong?
This topic is currently under discussion and there is possibly a pattern among R32 GTR owners. The PowerFC used is the same version as the R33 GTR PowerFC but this bug/problem only appears on R32 Skyline's. An intermittent misfire problem when coming on full load seems to be the common factor.
8.04a and 8.0 are known versions to be affected by this bug.
I installed a new engine cover (the bit in the middle that covers the coil packs) - this allowed me to move the ignitor pack back up on top of the engine cover. I took that opportunity to make sure I had a good earth when I moved it (which I assume the guys from Mercury have not) Prior to having the engine cover on - the coils and the ignitor pack shared the same earth - and I was just using one of the screw holes that holds the coil pack (plug) leads in place I plan to make a dedicated earth strap over to the -ve battery terminal over the weekend
Australia Area Rep
Discussion Starter #20
Part 17
The user reports that "New earth for the ignitor pack fixes it"
Thanks Scott
For an ongoing discussion you view it here This is a confirmed unofficial bug in the RB26 R32/R33 GTR LJetro PowerFC. This has been seen by quiet a few users with reproducable results. You should read the Skylines Australia thread above for known workarounds and fixes etc.
Is there a replacement hand controller screen?
As an unofficial replacement hand controller screen you can check out here for a suitable 128x128 backlit LCD. It even comes in different colours to be cool. I am unsure if this model works OK with the apexi hand controller.
I have tried using the Sieko screen on my personal hand controller work bench and it did not work.
The screen simply refuses to power up and light up. Try it yourself if you wish - you might get lucky.
I have fried my PowerFC. Is it fixable?
We have seen on a few occasions that an Apexi PowerFC is in fact fixable and can be repaired. The usual suspects are burnt tracks, fried chips or damaged circuits on the board itself. One member was able to send their PowerFC to a local electronics shop with a wiring diagram for their PowerFC. The shop ran a multimeter debug and replaced a few capacitors and resistors. The unit now works and remains to operate correctly. Previously the unit would not power up at all (blank screen and no fuel pump). The original fault was caused by a mismatched wiring configuration which shorted out a few fuses and the PowerFC failed at this stage. Your last resort would be to try a local electronics shop to try and debug what is failed or damaged. I would expect a $150 repair bill to be about normal for this sort of work. The other option is simply to buy a new or used PowerFC.
Everything is fixable its just a matter of how much will it cost :D - ask your local mechanic/auto elec shop for a quote if you have toasted your PowerFC
I always have knocking, is it true, is it lies or is something wrong?
The factory knock sensors are exactly that, small microphones attached to the outter casing of the block and they listen for certain frequencies. The frequencies they detect are those heard when detonation occurs. Hence the name, knock sensors. To sense engine knocking/detonation. Is it possible for knock sensors to detect other noises and vibrations from the engine (and road/environment) but they usually do indicate a problem.
The knocking level found in the Apexi PowerFC refers to the level of knock detected not the frequency. Higher voltage indiciates a bigger knock has been heard or detected and it is displayed on the hand controller.
You cannot alter the sensitivity of the knock sensors. You can alter the flash sequence or how often it should flash when a certain knock level is reached (using Datalogit).
A knock or 50 when the engine is on small amount of load at 3300rpm is much different to a knock of 50 when the engine is on full load at 5800rpm. The higher the load and RPM the harder the engine is working, the more likely detonation is going to occur, and the severity of it also increases. Knocking in low rpm can often be overlooked or just accept the fact and move on with things, but knocking under full load near mid to high RPM is a concern and always should be.
Do NOT ignore detonation - it can be an engine killer if ignored and the driver acts like a stupidhead - always check and find the cause or speak to your tuner. If the engine light is flashing its for a reason - get it sorted or be prepaid for heavy rebuild costs etc. It is better to be over-reactive when dealing with knocking than to ignore it and play the dumb driver "i didn't know"
How do I debug knocking, how can I make it go away?
There are 5 methods that come to mind immediately when dealing with knocking and their apporaches are listed below. Before you go ahead and try to be a cowboy fixing knocking if you aren't comfortable etc or don't know what you are doing go and see your tuner. Tell them all the information you have and get it sorted - Don't ignore it or just hope for the best. Either fix it yourself or speak to your tuner.
1. Use temporary IGN adjust
Drive around and replicate the concering knock levels, be sure to note roughly where it happens (rpm or load etc).
SETTING -> INJ/IGN Adjust -> Press DOWN 3 times and you will see -3 for IGN ADJUST. This drops the IGN map 3 degrees timing temporary (will reset when car is powered off).
Drive around and try to replicate the knocking levels again, be sure to try and reproduce the engine load and rpm you did previously. If the knocking has dropped considerably or has gone away completely (very likely) then it is simply a few cells on the IGN map have too much advanced timing.
You should give this information to your tuner;
Max Knock of: 50
At RPM: 4700
At Engine Load: Max Load (throttle was nailed)
Using Fuel: Standard BP Premium
Adjustments: -3 deg IGN timing fixed the problem
The tuner then has enough information to drop onto the IGN map and take out 3 deg timing where 4700 and max load lands on the IGN map. Should take no more than 5 minutes to correct and all be happy. The blanket and braindead approach is to drop the whole map 3 deg either using Datalogit or dialing the crank angle sensor backwards a notch, this is NOT recommended as its braindead. You have stand alone engine management, it should be used like one.
2. Use higher octane fuel
Find a local service station with really high octain rated fuel, Shell V Power Racing is a good one. Plonk in a full tank of V Power Racing in and drive around for about 5 minutes to get the fuel flowing.
Drive around and try to replicate the knocking levels again, be sure to try and reproduce the engine load and rpm you did previously. If the knocking has dropped considerably or has gone away completely (very likely) then it is simply a few cells are possibly too lean on the INJ map (could also be IGN timing). Running a much higher octane rated fuel is almost guaranteed to take away some detonation. I am using Shell V Power Racing (100ron) and its fantastic as a detonation killer (highly recommended).
3. Adjust IGN map
Max Knock of: (highest level you saw)
At RPM: (what RPM you noticed the engine check light come on)
At Engine Load: (driving conditions)
Using Fuel: (what fuel you used)
The tuner then has enough information to drop onto the IGN map and take out 2 degrees timing where your driving conditions land you on the IGN load map. Should take no more than 5 minutes to correct and all be happy. The blanket and braindead approach is to drop the whole map 3 deg either using Datalogit or dialing the crank angle sensor backwards a notch, this is NOT recommended as its braindead. You have stand alone engine management, it should be used like one.
4. Blanket approach
The blanket and braindead approach is to drop the whole map 3 deg either using Datalogit or dialing the crank angle sensor backwards a notch, this is NOT recommended as its braindead. You have stand alone engine management, it should be used like one. Lowering IGN timing is likely to take away any detonation but will certainly give the engine a flat and empty feeling (not recommended).
5. Ground Zero approach
Set the IGN timing from 4500rpm to 6000rpm at zero degrees.
Set the INJ map from the same load areas to 10.5 to 1 (mega rich).
That should complete eliminate any knocking, that is it is not humanly possible for it to knock now. Do a max load dyno run (damn it will be boggy and make jack all power) and see what knock levels you get now. If you still see knocking then its likely the sensors are picking up other mechanical noises in the engine bay. Using a chassis ear tool would assist in debugging where the noise is coming from.
One owner reports;
"Then I went for a little walk around the engine bay on the dyno with the chassis ear. It turned out to be the remote oil filter sandwich plate tapping on the oil pressure gauge adaptor. They were located right under the rear knock sensor. There was obviously was a slight engine vibration at that RPM, which I later traced to an unbalanced pressure plate."
So it certainly is possible for other external factors to cause "knocking" and thats the Ground Zero, rule out everything else approach.
My car won't start when I plug in the PowerFC, but the stock ecu works fine
First when dealing with a new PowerFC install and the car does not start there are a few basics to check;
• Check the PowerFC to car loom connector
• Check the warning lights on the dash, do they come up?
• On the hand controller, goto ETC, SENSOR SW CHECK, are any sensors highlighted in black? (Shouldn't be)
• Make sure you disable the Boost Control Kit if you aren't using it
1 - 20 of 41 Posts
