1 - 3 of 3 Posts
Denmark Area Rep
Hi there
My GT NA has been acting up lately..
When i drive in low revs (under 2K) in 2nd and 3rd and hold it on a steady speed, the car starts to.. umm.. oscillate back and forth, and just keeps on doing it at the same rate (aprox once a sec) until i rev over 2000rpm.
If i press the clutch pedal, the rocking stops.
Any ideas to whats wrong?
Clutch plate/flywheel?
Sparkplugs?
Coils/wiring?
Fuel system?
Im a bit lost.
/Kim
it has nothing to do with clutch system or ignition system it will be a fault in the idle control valve or aac valve.
pull them off and clean them and check your plugs are the correct ones and the gap is correct as well.
get that fault in loads of older cars
1 - 3 of 3 Posts
