this is probley a really silly question/idear but if you had a smaller water pump pully made and fitted the pump would spin faster, pumping water around the engine at a higher speed, would this cool the engine faster and better?
is it worth having a smaller pully made as mine is bent and i need another either way.
what water pump pullys fit the rb25 waterpump??
is there a smaller pully that fits, the ca18det is bigger and the bolt holes dont line up and the center hole is smaller.
i dont mind re-drilling the holes to fit a smaller one if the idear would work.
