NEW TO ALL THINGS NISSAN
Hi as the title suggest's : I am after a GTR Brake fluid reservoir to fit in my GTS..
:attention:
Hope someone can help :)
Many Thanks
Martin :cheers:
GTS/GTS-T/GTR Master Cylinder & GTR Brake Fluid res. in GTS...
Is this just so you can fit your stainless steel cover to it? A gtst one is the same IIRC, but I'm not sure if they fit your car without changing the master cylinder too anyway.
:) Yeah thats the reason :) lol.. You say the 'Master Cylnder too ?? Would a GTS-T master cylinder work or would it have to be from a GTR ??
Whats the difference between the GTS & GTR brake fluid reservoirs ''' size etc.. ??
I may do this if it doesn't work out too costly, do you think there will be any/if at all actual brake performance increase etc.. (if fitted alone and/or with the GTR Master Cylinder) .. or whether it'll make no difference at all just cosmetically so my shiny chrome cover fits as it should !? - Martin.
Hi
We have this in stock, please call or pm for more info.
Nat
Sweet :) how much? and do you know if I can take the GTS one straight off and swap it for the GTR one ...or like another member said...will I need a GTR master cylinder etc.. as well ??
Please reply asap
Regards
mrm artinhalliday
