any1 got a pressure kit to check where my leak is and is close to crawley ran engine up2 temperature and cant see leak cheers
West Sussex Area Rep
Most common place is the water lines behind the engine. My old R33 had a pin hole leak there. ***** to get to!
Thought it would be. Glad you found it! mine was in the metal pipe itself. I cut the metal pipe and replaced it with rubber water line.
no, I managed to squeeze my hand in. but like I said I cheated and cut the metal pipe and fitted a longer rubber one. worked fine.
