I have an intermittent starter fault on my BNR32, Its only happened twice and the last time it happened I ended out me calling the AA out to Wynyard Services ( this Sunday, and the wife was not pleased).
The first time it magically cleared over night.
I turn the ignition on
all the dash lights light up as expected
Turn the key to initialise the starter NOTHING. Not even a click !!
The AA guy gave the starter a direct feed and it fired up straight away, and said there is a fault from the ignition barrel to the solenoid as its not getting a signal
As the starter worked as above I rule out the imoboliser playing up.
Its now back working as normal but I cant get my head around why its happening so intermitantly
Any one got any Idea what it could be ? how to diagnose ? has any one had the same problem and can point me in the right direction? Can any one explain the wiring path from the ign barrel to the starter ?
TIA
Kevin
TIA
Kevin
